    Does "C" equal "C" ?
    14 Posts 8 Posters 957 Views 8 Watching
      MartinRinehart
      Edit: Of course "C" equals "C", (if you don't compound one mistake with another). 😳 Got a better way to handle the WebDialog.set_file() issue, which I'll add to that subject's discussion. Otherwise, this was just stupidity that I'll blame on too much snow shoveling.
      Back to the WebDialog.set_file() problem. I stumbled across the Ruby File.expand_path() method that looks like a better replacement for the little fixup() function I wrote. If you File.expand_path(__FILE__) you get the full path back to the root, on a Mac, or the drive, on a PC. Perfect!
      Except that "C:..." does not equal "C:..." in the following:
      # /models/airshow/t.rb
      =begin
      On a PC, WebDialog.set_file() requires a drive specification.
      So you get the working directory; dir = Dir;;pwd()
      The working directory will start with;
      '/' on a Mac
      'C;' (or 'D;' or ...) on a PC
      47 == '/'
      58 == ';'
      Prefix the given pathname with 'C;' (or 'D;' or ...) unless
          a) you are on a Mac
          b) the given pathname already includes a drive specification
      =end
      def fixup( pathname )
          dir = Dir;;pwd()
          pathname = dir[0..1] + pathname unless
              ( dir[0] == 47 ) || ( pathname[1] == 58 )
          return pathname
      tfile = 'movie_titles.html'
      foo = File.expand_path( File.dirname(__FILE__) )
      foo = File.join( foo, tfile )
      puts foo = 'foo; "' + foo + '"'
      bar = fixup( File.dirname(__FILE__) )
      bar = File.join( bar, tfile )
      puts bar = 'bar; "' + bar + '"'
      puts 'same? ' + (foo==bar).to_s
      Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
        Jim
        try using p str or puts str.inspect instead of puts str to see the exact string including the escape chars.
          what is the intent of the code?
            todd burch
            puts foo = 'foo: "' + foo + '"'
            puts bar = 'bar: "' + bar + '"'
            Of course they are not the same.
              MartinRinehart
              Good idea, tho in this case it wasn't an escape chars issue.
              To replace a call to my routine with a better use of Ruby:
              # this code works, PC and Mac, any way that __FILE__ was loaded
              pathname = File.expand_path( File.dirname(__FILE__) )
              pathname = File.join( pathname, 'myFile.HTML' )
              wd.set_file( pathname )
              Snow-blind coder error. 😳
              • chrisglasierC Offline
                chrisglasier
                Back to Uncle Holly stuff ... sigh
                With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
                  Jim
                  Everyone's done it. Yesterday I wrote this as an example:
                  def = Sketchup.active_model.selection[0].definition
                    ...and I can't see what's wrong... ...time to go home...
                    • Chris FullmerC Offline
                      I'm glad that I've nevre mis-typed or mis-comprehended a single line of code, so I don't even begin to comprehend what you guys are talking about 🤣
                      All my Plugins I've written
                        todd burch
                        def is a reserved word.
                          duh! I would have seen that with syntax highlighting... 😳
                            jessejames
                            WOW, good catch Todd, will you provided your eagle eye services to debug some of my code? 🤣
                            PS: i hope your rates are "reasonable" 😕
                            Always sleep with a loaded gun under your pillow!
                              jessejames
                              @ Todd 😳 it seems that you are actually replying to ThomThom and not Jim and in that context your comment makes sense. The way you quoted it it looked like you where replying to Jim directly so looks like i am the boob here!
                              • Dan RathbunD Offline
                                Dan Rathbun
                                @martinrinehart said:
                                ... I stumbled acrossthe Ruby File.expand_path() method that looks like a better replacement for the little fixup() function I wrote. If you File.expand_path(__FILE__) you get the full path back to the root, on a Mac, or the drive, on a PC. Perfect!
                                If you look back at the original thread, and reread more carefully, you'll see ThomThom told you to use File.expand_path() two weeks before you "stumbled across" it!
                                I've been wondering why you didn't take his advice... (and do you have a copy of the 'Pick-Axe' Ruby book in chm format?)
                                I'm not here much anymore.
