    Does "C" equal "C" ?
    14 Posts 8 Posters 1.3k Views 8 Watching
      Jim
      try using p str or puts str.inspect instead of puts str to see the exact string including the escape chars.
        what is the intent of the code?
        • T
          todd burch
          puts foo = 'foo: "' + foo + '"'
          puts bar = 'bar: "' + bar + '"'
          Of course they are not the same.
            MartinRinehart
            Good idea, tho in this case it wasn't an escape chars issue.
            To replace a call to my routine with a better use of Ruby:
            # this code works, PC and Mac, any way that __FILE__ was loaded
            pathname = File.expand_path( File.dirname(__FILE__) )
            pathname = File.join( pathname, 'myFile.HTML' )
            wd.set_file( pathname )
            Snow-blind coder error. 😳
            • chrisglasierC
              chrisglasier
              Back to Uncle Holly stuff ... sigh
                Jim
                Everyone's done it. Yesterday I wrote this as an example:
                def = Sketchup.active_model.selection[0].definition
                  ...and I can't see what's wrong... ...time to go home...
                  • Chris FullmerC
                    I'm glad that I've nevre mis-typed or mis-comprehended a single line of code, so I don't even begin to comprehend what you guys are talking about 🀣
                    • T
                      todd burch
                      def is a reserved word.
                        duh! I would have seen that with syntax highlighting... 😳
                          jessejames
                          WOW, good catch Todd, will you provided your eagle eye services to debug some of my code? 🀣
                          PS: i hope your rates are "reasonable" πŸ˜•
                          Always sleep with a loaded gun under your pillow!
                            jessejames
                            @ Todd 😳 it seems that you are actually replying to ThomThom and not Jim and in that context your comment makes sense. The way you quoted it it looked like you where replying to Jim directly so looks like i am the boob here!
                            • Dan RathbunD
                              Dan Rathbun
                              @martinrinehart said:
                              ... I stumbled acrossthe Ruby File.expand_path() method that looks like a better replacement for the little fixup() function I wrote. If you File.expand_path(__FILE__) you get the full path back to the root, on a Mac, or the drive, on a PC. Perfect!
                              If you look back at the original thread, and reread more carefully, you'll see ThomThom told you to use File.expand_path() two weeks before you "stumbled across" it!
                              I've been wondering why you didn't take his advice... (and do you have a copy of the 'Pick-Axe' Ruby book in chm format?)
                              I'm not here much anymore.
