    Texture coords randomiser
    2 Posts 2 Posters 668 Views 2 Watching
      jamma-pcb
      Hi all
      Does anyone know of a plugin that can randomise the position of a texture on a object/face.
      The reason is I have 4 of the same components but each duplicated replicates the same texture coords....
      Normally each object then becomes unique and I have to manually alter the position of the textures so they dont look so fake (nothing in this world is that exact texture wise)
      So I'm after a plugin that can make this job fast... A simple click make object unique and then highlight all faces and randomise the texture coords.
      Any suggestions
      • massimoM Offline
        massimo Moderator
        Hi, you can try the "rantexpos.rb" plugin. Scroll down, they are in alphabetical order. Be careful it's a bit buggy if I remember well.
