    Clay Renders in Podium
    extensions
    6 Posts 4 Posters 2.8k Views 4 Watching
      AZPilot
      Can someone point in the direction of a tutorial of how to create clay renders in Podium? I've followed all the info I can find, but my renders are not coming out. I can barely see the model against the background. I know I'm missing something but not sure what I'm missing.
      Todd
      Chandler, AZ
        dylan
        You should receive an answer here, but I would advise asking over at the Podium forum. There is lot's of great help there.
        http://supodiumforum.websitetoolbox.com/
        http://dmdarchitecture.co.uk/
          sepo
          Choose the colour of the front face. Select colour by layer. Render.
          If you had default tan colour the render will look very pale. I suggest you setup front face colour darker. Power of sun no more than 20 (dark slider) and add soft shadows.
          • numbthumbN Offline
            numbthumb
            Should we uncheck the sky option in SU when doing a clay render? And what about the background color?
            Comfortably numb...
              sepo
              It is up to you if you want to have sky in or not. If you decide not than sky of and backgroound colour off white.
                numbthumb
                Thanks!
                Comfortably numb...
