    Model.edit_transform for parent
    11 Posts 4 Posters 818 Views 4 Watching
      cjthompson
      Is there any way to get the local transformation for a component that is not at the end of the active path?
      For example, say I double click a component, and then double click a component inside that one. I want to find the local transformation of the first.
        model.edit_transform gives the current edit's transformation
        To find the transformation of the 'first' parent you need to iterate down the tree until it's the one before 'model' - so something like...
        ### first you somehow set 'entities' to the current edit's entities set and find the parent e.g.
        parent=entities[0].parent
        ### then
        done=false
        until done
          if parent.entities[0].parent == Sketchup.active_model
            done=true
          else
            parent=parent.entities[0].parent
          end#if
        ### parent is now the first container ?
          cjthompson
          I can get the instance I'm looking for, but I'm having problems getting the actual transformation, since it is also in edit mode, but not the current edit mode.
          I was able to find instance.local_transform, but it is undocumented.
          Basically, I'm trying to use an input point to iterate up the model to find the component's path, instead of drilling down to find it.
            instance.local_transformation seems to return nothing useful...
            Working down towards Model will give you the entity's ultimate container - then you can find its transformation ?
            If the final container is a component-definition then you're stuffed as you'll want the actual instances' transformation
            You can't easily get the transformation of an entity inside an Instance of a Definition - get the entity's transformation within the Definition and then adjust it by the containing Instance's transformation [and then that's container's transformation etc etc] so you should somehow be able to apply that to the entity's too ? πŸ˜•
              Jim
              I would guess the local_transformation method has its origin as part of Dynamic Components. It's not mentioned in the API docs at all.
                cjthompson
                It looks like its inherited from drawing element, so you can use it on faces and edges, too.
                  Model.active_path
                  http://code.google.com/apis/sketchup/docs/ourdoc/model.html#active_path
                  use that to traverse the path up to the current
                  model.edit_transform * model.active_path.last.transform.inverse
                    Get help from a pickhelper?
                    http://code.google.com/apis/sketchup/docs/ourdoc/pickhelper.html
                      cjthompson
                      except you can't pick outside of edit mode.
                      I solved it by just drilling down the model structure, instead of going up it like the original idea.
                        yes you can.
                        once you do a pick you get an array of various pick solutions.
                        .all_picked returns a list of all the top level entities for each possible path. .count return the number of possible paths. Use .path_at to get a drill down path for the given index.
                          cjthompson
                          sorry, I must be really tired today. I meant you can't use a pickhelper outside of the current context. so If you you have two instances in the model, and you double click one, you can't use the pickhelper on it's sibling.
