    [code] 3ds2obj.rb
    15 Posts 3 Posters 3.4k Views 3 Watching
    • J
      Jim
      This is not a plugin - but a rudimentary code snippet that extracts data from a binary .3ds and outputs it to std out.
      usage:
      $ 3ds2obj.rb model.3ds > model.obj
      3ds2obj.rb
      • thomthomT
        You got hold of file format specs for 3ds?
        • J
          Jim
          It is readily available online.
          • X
            xrok1
            thomthom, does it work, does it work?? πŸŽ‰
            β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
            • thomthomT
              A bit early to ask that. πŸ˜‰
              • J
                Jim
                It appears there is a CAMERA chunk (0x4700), so if you can't find the format for that chunck, then you should be able to dump the chunk and view it in a hex editor to see if it can be deciphered.
                So once the chuck is identified, it is followed by its length. this line gives you the number of bytes to read the rest chunk:
                when 0x4700
                  puts "# CAMERA DATA"
                  # NOT sure of the proper way to unpack?
                  chunk_len = f.read(2).unpack('s')[0]
                  chuck_len.times do
                    # something?
                  next
                • J
                  Jim
                  Whoops, check that command-line example I gave for usage - I changed it.
                  • J
                    Jim
                    getting closer..
                    * 4700 - Camera
                     Describes the details of the camera in the scene
                     start end size type   name
                      0     3   4   float  Camera pos X
                      4     7   4   float  Camera pos Y
                      8    11   4   float  Camera pos Z
                     12    15   4   float  Camera target X
                     16    19   4   float  Camera target X
                     20    23   4   float  Camera target X
                     24    27   4   float  Camera bank ( rotation angle )
                     28    31   4   float  Camera lens
                    • J
                      Jim
                      I see , the camera is a fixed-length chuck so has no length - you just start reading the values:
                      when 0x4700
                              xpos = f.read(4).unpack('f')[0]
                              puts "xpos;#{xpos}"
                              ypos = f.read(4).unpack('f')[0]
                              puts "ypos;#{ypos}"
                              zpos = f.read(4).unpack('f')[0]
                              puts "zpos;#{zpos}"
                              next
                      Although strangely the values are close but not exact as:
                      Sketchup.send_action(10624)
                      • thomthomT
                        Ah, I see. It's a standalone ruby - not a SU ruby. have not looked at the code yet.
                        28 31 4 float Camera lens - what would this be then?
                        • thomthomT
                          when 0x4700
                          >         puts "xpos;#{xpos}"
                          >         puts "ypos;#{ypos}"
                          >         puts "zpos;#{zpos}"
                          >         next
                          would this not be doing the same?
                          xpos, ypos, zpos = f.read(12).unpack('fff')
                          a one-liner.
                          • thomthomT
                            How close? Minor - something that could be explained by floating precision?
                            • J
                              Jim
                              Maybe - I'm in "make it work" mode. Optimize mode comes later.
                              • J
                                Jim
                                Yeah, that's pretty much all there is to it. Make sure to read all the values; you can't skip them even if you don't use them.
                                I made a mistake when I said the values did not match - it works out no problem.
                                when 0x4700
                                        puts "eye; (#{xpos}, #{ypos}, #{zpos})"
                                        tx, ty, tz = f.read(12).unpack('fff')
                                        puts "target(#{tx}, #{ty}, #{tz})"
                                        rotation = f.read(4).unpack('f')[0]
                                        puts "#rotation;#{rotation}"
                                        lens = f.read(4).unpack('f')[0]
                                        puts "#lens;#{lens}"
                                        next
                                • thomthomT
                                  Because of variable chunk length?
                                  You managed to recreate an SU camera?
                                  What's the lens value? AOV? FOV?
