    [code] 3ds2obj.rb
    15 Posts 3 Posters 3.4k Views 3 Watching
      You got hold of file format specs for 3ds?
        Jim
        It is readily available online.
        • X Offline
          xrok1
          thomthom, does it work, does it work?? πŸŽ‰
            A bit early to ask that. πŸ˜‰
              Jim
              It appears there is a CAMERA chunk (0x4700), so if you can't find the format for that chunck, then you should be able to dump the chunk and view it in a hex editor to see if it can be deciphered.
              So once the chuck is identified, it is followed by its length. this line gives you the number of bytes to read the rest chunk:
              when 0x4700
                puts "# CAMERA DATA"
                # NOT sure of the proper way to unpack?
                chunk_len = f.read(2).unpack('s')[0]
                chuck_len.times do
                  # something?
                next
                Jim
                Whoops, check that command-line example I gave for usage - I changed it.
                $ 3ds2obj.rb model.3ds > model.obj
                  Jim
                  getting closer..
                  * 4700 - Camera
                   Describes the details of the camera in the scene
                   start end size type   name
                    0     3   4   float  Camera pos X
                    4     7   4   float  Camera pos Y
                    8    11   4   float  Camera pos Z
                   12    15   4   float  Camera target X
                   16    19   4   float  Camera target X
                   20    23   4   float  Camera target X
                   24    27   4   float  Camera bank ( rotation angle )
                   28    31   4   float  Camera lens
                    Jim
                    I see , the camera is a fixed-length chuck so has no length - you just start reading the values:
                    when 0x4700
                            xpos = f.read(4).unpack('f')[0]
                            puts "xpos;#{xpos}"
                            ypos = f.read(4).unpack('f')[0]
                            puts "ypos;#{ypos}"
                            zpos = f.read(4).unpack('f')[0]
                            puts "zpos;#{zpos}"
                            next
                    Although strangely the values are close but not exact as:
                    Sketchup.send_action(10624)
                      Ah, I see. It's a standalone ruby - not a SU ruby. have not looked at the code yet.
                      28 31 4 float Camera lens - what would this be then?
                        when 0x4700
                        >         puts "xpos;#{xpos}"
                        >         puts "ypos;#{ypos}"
                        >         puts "zpos;#{zpos}"
                        >         next
                        would this not be doing the same?
                        xpos, ypos, zpos = f.read(12).unpack('fff')
                        a one-liner.
                          How close? Minor - something that could be explained by floating precision?
                            Jim
                            Maybe - I'm in "make it work" mode. Optimize mode comes later.
                              Jim
                              Yeah, that's pretty much all there is to it. Make sure to read all the values; you can't skip them even if you don't use them.
                              I made a mistake when I said the values did not match - it works out no problem.
                              when 0x4700
                                      puts "eye; (#{xpos}, #{ypos}, #{zpos})"
                                      tx, ty, tz = f.read(12).unpack('fff')
                                      puts "target(#{tx}, #{ty}, #{tz})"
                                      rotation = f.read(4).unpack('f')[0]
                                      puts "#rotation;#{rotation}"
                                      lens = f.read(4).unpack('f')[0]
                                      puts "#lens;#{lens}"
                                      next
                                Because of variable chunk length?
                                You managed to recreate an SU camera?
                                What's the lens value? AOV? FOV?
