    Roger seller bath
    7 Posts 3 Posters 956 Views 3 Watching
    • garydornG Offline
      garydorn
      A client of mine wants to use a Rogerseller Zuric Bath
      http://rogerseller.com.au/launch.aspx
      http://www.rogerseller.com.au/images/products/LG_206100.jpg
      The dxf download is just section and elevation
      the pdf includes the plan
      http://rogerseller.com.au/pdfs/install/Zuri%20Install%20HR.pdf
      how do I model a curved bath like this?
      chow
        d12dozr
        I would use TIG's Extrude Edges by Rails found here: http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
        Make the top rail from the top plan, then the bottom rail from the bottom of the tub, then the profile from the elevation view...hit go! It may work best to do it in halves then put them together...
        http://goo.gl/f7ooYh
        • boofredlayB Offline
          boofredlay
          Personally I would do it the traditional way as it is pretty symmetrical.
          Import the image and trace half of the profile.
          Trace the base of the tub. Align the profile with the base then select that base plan face and use the follow me command on the profile.
          Do some clean up and smoothing and you are done.
            boofredlay
            And to save you even more time, here is the model. πŸ˜‰
            Zuric_Bath.skp
              d12dozr
              Yours is better yet Boo, I guess with the fancy new plugins, I lose sight of the forest for the trees πŸ˜•
              • garydornG Offline
                garydorn
                "And to save you even more time, here is the model. πŸ˜‰"
                Oh fantastic
                thanks very much
                I'll have a go later according to what you did to learn how to do it for other stuff
                cheers
                  boofredlay
                  Glad I could help.
