    Entering measurements
    5 Posts 2 Posters 1.1k Views 2 Watching
    • pmolsonP Offline
      pmolson
      I would like sketchup to protect me from myself.
      Currently, the proper way to enter measurements in feet and inches is like this..
      10'5", 6'5 1/2"
      Many cad programs require a dash between the foot and inches. (10'-5",6'-5 1/2" Its a habit
      I am successful in not doing when using sketchup about 98% of the time.
      On the 2% occasions when I enter the measurements with a dash, the object
      I am moving or line that i am drawing will move or draw, but not at the
      correct distance. If One does not catch the error immediately it can cause
      serious problems as the model progresses.
      I would like to see the measurement function "reject" the incorrect input rather than
      carrying out an incorrect distance operation.
      Maybe the dash is read as a negative and is adjusting the foot measurement by a negative inch amount.
      I have not taken the time to look for rhyme or reason in the distance that results from an incorrect
      entry. Maybe there is a useful reason for the use of the dash that I am not aware of.
        Rob D
        Mate. I had a conventional think and couldn't come up with anything useful.
        So here's a solution using a bit of lateral thinking...
          Rob D
          • pmolsonP Offline
            pmolson
            πŸ˜† πŸ˜† πŸ˜†
            Thats It! Brilliant!
            I think you have cured me. Even without placing a tack on the dash key,
            I think I will subconsciously feel it there.
            p
              Rob D
              πŸ˜† We can now add psychologists to SketchUp's user list πŸ˜„
