    IMAGE/ TEXTURE INTERFERENCE
    12 Posts 3 Posters 956 Views 3 Watching
    • J
      jonathanb
      Can anyone explain why when i insert images or textures into sketch up they seem to be affected by another texture? For example, i find that if i insert an image it often has a black bar across one side of the image, which, when i zoom in disappears. It has only just started happening recently. Other times it has another texture that i have imported affecting another material. It is rather strange!!
      Appreciate any thoughts.
      • J
        jonathanb
        Here is an example with just an image imported into my model. You can see a black line along the bottom.
        Hanoi.skp
        • thomthomT
          Can you post a screenshot?
          Does it happen when you turn off Hardware Acceleration? (if it does - update your drivers.)
          • thomthomT
            hmm... no?
            • J
              jonathanb
              this is as it is shown on my screen, perhaps it is something to do with my drivers as you say?
              • J
                jonathanb
                oh that's really wierd, it shows it on my screen in the model but not when i export an image or render a scene....
                what do you mean by Hardware Acceleration?
                • thomthomT
                  Try to use the PrintScrn button on your keyboard to capture what's actually on your screen - and paste it into Paint or PhotoShop or similar.
                  I'm pretty sure this is a graphic card driver problem.
                  What graphic card do you have, and when was the last time you updated their drivers?
                  • GaieusG
                    If it is different on the screen and in the exported image, it definitely sound like a video subsystem problem. On my screen, it looks just as expected.
                    • J
                      jonathanb
                      Well i have turned off the hardware acceleration and the problem seems to be resolved, thanks! will this have an impact on any rendering that in do in the future?
                      As far as the graphics card is concerned i'm not sure exactly to be honest but probably a while ago... i was left with this old machine so have to make do!! i can ask our technical guys and this may solve the problem. Thank you.
                      • J
                        jonathanb
                        oh and here is the print screen for any future reference
                        • thomthomT
                          Yes - it makes your CPU do all the work. It will be considerable slower. The real solution would be to update the drivers.
                          • GaieusG
                            Or even a new card - in case it is really that old computer (although sometimes you do not want to spend money on an old machine any more - and most of the modern cards may not even be compatible with your motherboard)
