    Move point?
    6 Posts 3 Posters 491 Views 3 Watching
    • A
      alz
      (newb question here)
      With "ComponentInstance" and "tranformation" you can move a selected component around.
      Is there a way to move a selected point around? Or does it get complicated by having to select an edge, then find the points in it to move?
      • TIGT
        You can move Instances/Groups, Points and Vertices.
        You apply transformations to most but for vertices you must use another method
        'Transformations' can be points, translations, rotations and scaling etc...
        tr=Geom::Transformation.translation([0,0,1]) ### =='changes' something; here == move it up 1 unit...
        group.transform!(tr) ### =='changes' the group by 'tr', up 1 unit...
        or
        point.transform!(tr) ### =='changes' point by 'tr', up 1 unit...
        but for a vertex or vertices you need to use...
        entities.transform_entities(tr,[vertices])
        here an array (list) of vertices have 'tr' applied...
        or
        entities.transform_by_vectors([vertices],[vectors])
        you take an array of vertices and apply an array of vectors to do the translation...
        So for one vertex
        entities.transform_by_vectors([vertex],[[0,0,1]]) ### moves vertex by vector up 1 unit in Z...
        You can also apply these 'entities.transform....' methods to any collection of 'things' like an array of group.entities...
        • A
          alz
          Very cool! Thanks for the examples, TIG!
          The difference between 'point' and 'vertex' is construction point vs. edge point?
          • thomthomT
            ConstructionPoint is a construciton point Entity.
            Vertex is the end points of Edges.
            Point3d is just a point in 3d space.
            • TIGT
              ...and vertex.position returns the point in space that the vertex is πŸ˜„
              • A
                alz
                Awesome -- all very helpful bits of info!
