    Scene and Styles
    6 Posts 3 Posters 479 Views 3 Watching
    • kenK
      ken
      Is there a plugin or someway to change Styles like there is with scenes. One click from one Style to another style.
      Ken
      • thomthomT
        why you need one? what would differ from the way SU do it?
        • kenK
          ken
          Thom
          I like the engineering style for display during design viewing. However, in the last couple of weeks I have discovered the advantage of drawing with the profile lines turned on and showing end points style. To me it has increased my accuracy and deceased my drawing time.
          I tried to make to scene tabs with one being just the engineering style so I could view the drawing and another scene tab with profiles and end points on. However, scenes will not remember these setting.
          So I thought maybe there was a pluging for this, like a toggle, from one style to another and back, that I didn't know about or some work around in Sketchup that I had missed.
          Thanks for you reply. Guess there is neither.
          • GaieusG
            Hi Ken,
            Go to your Preferences > General tab and check that "Warn..." box.
            From now on, any time you make some style change and add or update a scene, an annoying popup will appear asking you whether you want to update your style in use or add as a new style or do nothing. In order to have different styles (including profiles and endpoints) under your different scenes, you will want to "add" it as a new style.
            Experiment until you feel comfortable with this (and once in a while purge your styles, too, not to "collect" too many unused ones in your model).
            • thomthomT
              And you also got the Scenes window that let you change the properties of multiple scenes in one go.
              • GaieusG
                Also watch Chris Fullmer at the first quarter of this video. He is presenting how to use these different styles during his workflow with extensive models.
                [flash=600,360:2o4g313w]http://www.youtube.com/v/r9_F-bSGrKs&color1=0xb1b1b1&color2=0xcfcfcf&hl=en_US&feature=player_embedded&fs=1[/flash:2o4g313w]
