    Naming 'Untitled'
    3 Posts 2 Posters 268 Views 2 Watching
      MartinRinehart
      Your Ruby does a File/New. Create some geometry. model.save "myname.skp".
      Your SU still says it has "Untitled". Any way to tell it that it's got a name?
      Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
        Using model.save("myname.skp") DOES save it [overwriting any earlier files of that name without warning] - check in your current working directory - often /Plugins/... but best to give it a proper path...
        What you saved is NOT what is now open.
        BUT you can then open it with UI.openURL("myname.skp") leaving the original 'Untitled' one still open too OR better you can use Sketchup.open_file("myname.skp") to open that newly made file, with the 'Untitled' one being closed without saving... πŸ€“
          MartinRinehart
          Thanks, TIG. Any way to fire that extra "N" (don't save Untitled) from Ruby?
