    Optimization Tips
    110 Posts 22 Posters 193.2k Views 22 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      UI.show_inspector "Outliner"
      toggles it.
      Shows it if it's closed
      Rolls it up if it's shown
      Unrolls it if it's rolled up
      There's no way with the API to tell (now) what state it is in.
      I'm not here much anymore.
        I think Jim made a Windows hack to toggle a rollup...
        ### toggleWindows.rb - based on Jim's ideas - only for Windows...
        ### 20090401 TIG
        ### needs "win32api.so"
        if [PLATFORM].grep(/mswin/)==[PLATFORM] and Sketchup.find_support_file("Win32API.so","Plugins/")
        ### = a Windows machine
          require 'Win32API.so'
          def toggleRollUp(name)
            findWindow = Win32API.new("user32.dll","FindWindow",['P','P'],'N')
            pw=findWindow.call(0,name)
            sendMessage = Win32API.new("user32.dll","SendMessage",['N','N','N','P'],'N')
            sendMessage.call(pw,0x00a1,2,"")#WM_NCLBUTTONDOWN
            sendMessage.call(pw,0x0202,0,"")#WM_LBUTTONUP
          def isRolledUp(name)
            getWindowRect= Win32API.new("user32.dll","GetWindowRect",['P','PP'],'N')
            data=Array.new.fill(0.chr,0..4*4).join
            getWindowRect.call(pw,data);
            rect=data.unpack("i*")
            #if window height is less than 90 then the window is rolledup
            return (rect[3]-rect[1])<90
        end#if
        You add 'Outliner' to run it... test if rolled up, toggle roll up if not etc etc........
          Dan Rathbun
          its nice but...
          The windows have other language names in the loacalized versions.
          The code needs updating. It needs to search by ID instead.
          (Or have arrays of the Inspector captions in all the local versions.)
          It also should be in the SKX forum, either as a UI module extended method (which would be half done, as it's only Win32,) or a SKX::GUI::WIN method.. or something
            I only pass on Jim's hack... if you want to 'fix' it please do... It'd be better if the API had proper access to these anyway !
            • K Offline
              kwalkerman
              Dan, this is absolutely what I need. It is the updating of the UI that is slowing the calculation down. Having the outliner window open compounds the problem.
              Karen
                Karen
                You are using .start_operation with the disable_ui flag, right?
                Also, try to do as much as possible in bulk operations. Transform and erase in bulks. entities.erase_entities instead of entity.erase! etc.
                Cache calculation results - Ruby is horribly slow in crunching numbers.
                Often, methods that accepts Point3D objects can use Vertex objects as well - though the API docs doesn't mention this. If you are doing many iteration vertex.position will eat time. So try to feed the methods raw vertices instead.
                  Dan Rathbun
                  @dan rathbun said:
                  its nice but...
                  Ooops.. just checked. The Outliner does not have an ID.
                  But Jim's system call 'may' work. The window object can have a different "name" than the text displayed on the caption bar.
                  Someone running a non-English version could test it and let us know.
                    Dan Rathbun
                    @dan rathbun said:
                    @dan rathbun said:
                    The code needs updating. ...
                    Didier tested it and the results are both good and bad:
                    see: Re: Anyone with non-english Sketchup?
                      jessejames
                      @thomthom said:
                      What I found most interesting in those test was that Vertex is a valid argument where the manual claims only Point3d. And passing the Vertex is faster than Vertex.position.
                      Well i think you'll find this is a commonality of the API and the Docs is the fact that "those" who are creating the API and the Docs ARE NOT "those" who use it on a daily basis! πŸ˜‰
                      Always sleep with a loaded gun under your pillow!
                        Jernej Vidmar
                        Hi guys,
                        I have just found out that converting String to Length directly is up to 13x slower in comparision to converting it to Float first and only then to Length...
                        def string_to_length_conversion(iterations=100_000)
                        	a=0
                        	t1=Time.now.to_f
                        	iterations.times do
                        		# convert to Length directly
                        		a = '5,0'.to_l
                        	t2=Time.now.to_f
                        	puts "Conversion to Length directly took #{t2-t1} sec, a=#{a}"
                        	t1=Time.now.to_f
                        	iterations.times do
                        		# convert to Float, then apply units (meters in this case) and set to Length
                        		a = '5,0'.to_f.m.to_l
                        	t2=Time.now.to_f
                        	puts "Conversion to Length via Float took #{t2-t1} sec, a=#{a}"
                        #Conversion to Length directly took 1.84500002861023 sec, a=5,00m
                        #Conversion to Length via Float took 0.14300012588501 sec, a=5,00m
                          That is useful to know. But that assumes one has a string with only a numeral.
                          String.to_l will allow you to covert strings such as '20m' and '20mm'. With out any length unit indication in the string it will assume the length is in the unit of the current model.
                            BUT remember that .to_l parses any 'units' text to work out the actual value into inches...
                            So "1.0m".to_l >>> 39.3700787401575"
                            or "1'".to_l >>> 12"
                            BUT
                            "1.0m".to_f.to_l >>> 1.0"
                            and "1'".to_f.to_l >>> 1"
                            therefore you may as well miss out the second method .to_l as
                            "1.0m".to_f >>> 1.0
                            and "1'".to_f >>> 1
                            i.e. as a 'raw number'... AND 'raw numbers' are assumed to be in inches anyway == 1.0"...
                            Also .to_l and .to_f work differently if there is no 'unit' suffix...
                            If you have mm set as your current units then
                            "1".to_l >>> 0.0393700787401575 (inches)
                            but "1".to_f >>> [ruby:3h6c8mbs]1.0[/ruby:3h6c8mbs] (float/number),
                            and with inches as the current units
                            "1".to_l >>> [ruby:3h6c8mbs]1[/ruby:3h6c8mbs] (inch)
                            SO if you have an input that might be in anything other than inches and might have units in its string you do need to use .to_l or you risk returning a wrong value... πŸ€“
                              Dan Rathbun
                              + vs << vs "#{}"
                              Benchmark Test (at ruby-talk-google)
                              String concatenation in ruby
                                ` t=Time.now; 1000000.times{ 3**2 }; puts Time.now - t
                                0.948
                                nil
                                t=Time.now; 1000000.times{ 3*3 }; puts Time.now - t
                                0.216
                                nil`
                                  does the whole line have to be in c? im trying to map this out---
                                  %(#0040FF)[]
                                  What do you mean? Are you making a C Extension?
                                    THOM THOM WHAT KIND OF SCRIPTING LANGUAGE IS RUBY??????? 😐
                                    Sorry, but I don't understand what 'kind' you mean. Can you elaborate a bit more?
                                    And please, do not use all caps. It's hard to read and it's considered bad manners.
                                      Dan Rathbun
                                      Ruby is a 100% Object-Oriented Interpreted Scripting Language.
                                      See: "Ruby Newbie's Guide to Getting Started"
                                        Dan Rathbun
                                        If you are new to Ruby... learn Ruby scripting, don't worry about it's C source code, you'll just confuse yourself. (The Ruby interpreter engine just happens to be written in C and compiled. You don't need to know C unless your involved with actually maintaining / updating the Ruby Core libraries. This has noting to do with using Ruby or writing Ruby scripts, or using Sketchup.)
                                          i += 1 vs i = i.next
                                          i=0; t=Time.now; 10000000.times { i+=1 }; Time.now-t
                                          2.045
                                          i=0; t=Time.now; 10000000.times { i=i.next }; Time.now-t
                                          1.682
                                            2.045
                                            1.682
                                            So avoid i='0'; t=Time.now; 10000000.times { i.next! }; Time.now-t
                                            ~8.300 πŸ˜’
                                            • 6
                                            • 4 / 6
