    Enlarge a picture??
    10 Posts 6 Posters 495 Views 6 Watching
    • 3 Offline
      3eighty
      Before I give up the hunt I thought I would check with you all here.. Is there a program that will enlarge a BMP or JPG with any quality at all...Have just a couple of pics to enlarge but so far...nada...
      Thank You
      • Alan FraserA Offline
        Alan Fraser
        Photozoom is one of the best...much better than simply changing the resolution in an image editor.
        3D Figures
        • massimoM Offline
          massimo Moderator
          You can also try SmillaEnlarger, it's free and quite good.
            Thanks Massimo,
            Although I remembered that Alan had posted something before (and thanks for that, Alan, too) I could not find his post to recommend.
            Now as I would very rarely need such a tool, I wouldn't want to invest in it but I will check out this freebie you suggested.
            • 3 Offline
              3eighty
              Thanks for the ideas..Off to check them now.. 👍
              • mitcorbM Offline
                mitcorb
                Pilou:
                Your link goes directly to the photoenlarger interface.
                What's crazy is there is no introduction, or home page or anything I could tell.
                It requires that you get an image to start, and your default image folder opens when you click the "button" in the center of the screen.
                I tend to be a little on the cautious side and this unnerved me.
                But thanks for the hint.
                  @ Mitcorb : Sorry I have changed the link 😳
                  But if you had pressed the logo at up Top left page corner...all info were given 😄
                    try this crazzy one on line and free 😉
                    rsizr 😎
                    • mitcorbM Offline
                      mitcorb
                      You know, that occurred to me right after I had shut down for the day at the office.
                      Thanks for your reply.
                      • 3 Offline
                        3eighty
                        Mr Pilou> Thank you for the tip..It was pretty cool.. 👍
