    Texture scaling problem
    5 Posts 3 Posters 515 Views 3 Watching
    • G
      Glenn at home
      Hello all, I have an issue with textures not scaling correctly on cabinet blocks brought in from AutoCAD. In my picture you can see that I have some cabinets in my layout which I am applying textures too. Now the tall unit door seems to displaying my texture in a different scale. All units are components. Any ideas?
      TIA
      Glenn
      • thomthomT
        You applied the material to the component? And one of your component is scaled up/down from the original size?
        • G
          Glenn at home
          No, they are all scaled the correct size. The tall cabinet is exactly what it should be. They were all correct in AutoCAD too. It's really weird.
          • GaieusG
            Still it seems that the texture is scaled with that cabinet door. Are there two, separate texture images with the model? If not, try to right click on that component and "Scale definition". If it were a native SU model, this would fix the texture scaling issue.
            • G
              Glenn at home
              There was only one texture for the wood but I did right-click and make unique texture and scale that one so I found a work around just wanted to see if anyone else had seen this before.
