    Add a text on a point
    7 Posts 2 Posters 945 Views 2 Watching
    • P Offline
      Pauline01
      Re re hello, 😛
      I try to add on my group a text.
      The text will be contain the string of "adrresult"(see in my code).
      I have somes things but...
      In my code i want complete after : " #i want to associate the position of my text on a point
      #???? position_point_of_my_text = text.point "
      and
      " # text=addresult
      #??? textstring = text.text= addresult "
      thx again...
      require 'sketchup.rb'
      class Vsx
        @@Obj = nil
      def add_etiquette
        # Get "handles" to our model and the Entities collection it contains.
        model = Sketchup.active_model
        entities = model.entities
        # Create a series of "points", each a 3-item array containing x, y, and z.
        pt1 = [0, 0, 0]
        pt2 = [30, 0, 0]
        pt3 = [30, 0, 17]
        pt4 = [0, 0, 17]
        # Call methods on the Entities collection to draw stuff.
       # new_face = entities.add_face pt1, pt2, pt3, pt4
        group = entities.add_group
        group.entities.add_face(pt1,pt2,pt3,pt4)
        prompt = ["Zone Name"]
        val = group.get_attribute("MyDico", "Name_zone")
        default = [val]
        result = UI.inputbox prompt, default, "Enter the Zone Name"
        adrresult = result[0].to_s
        group.set_attribute("MyDico", "Name_zone", adrresult.to_s)
        UI.messagebox ("@ ; " + adrresult.to_s + " saved")
        # text=addresult
      #Menu
      if (not file_loaded?("zEtiquette_config.rb"))
          tool_menu = UI.menu "Tools"
      	tool_menu.add_item("Create zone item") {
          add_etiquette
      	$VSX = Vsx.new
        file_loaded("zEtiquette_config.rb")
        Entities.add_text
        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entities.html#add_text
        • P Offline
          Pauline01
          ok thx
            note that the third argument is optional. so you only need to spesofy the point and text. something like:
            group.entities.add_text('myText', position_point_of_my_text)
            • P Offline
              Pauline01
              ok, now i want can change my text contained in a group.
              In my second plugin, i have a menu to change "Name_zone" of the object selected.
              I can't change the 2D text of my object, because it contained in a group of entities.
              In my second plugin i want do this after "#I wish change my 2D text in the object selected
              It's possible or i delete my object and i create a new?
              My code who associate my text in a group of entities.
              thx again and again. I'am begining...
              First plugin:
              def add_etiquette
                pt1 = [0, 0, 0]
                pt2 = [30, 0, 0]
                pt3 = [30, 0, 17]
                pt4 = [0, 0, 17]
                coordinates = [0, 0, 8.5]
                point = Geom;;Point3d.new coordinates
                default = [val]
                group.entities.add_text adrresult.to_s, point
              Second plugin:
              def zonename
                prompt = ["Name"]
                val = Sketchup.active_model.selection[0].get_attribute("MyDico", "Name_zone")
                default = [val]
                adr = Sketchup.active_model.selection[0].set_attribute("MyDico", "Name_zone", adrresult.to_s)
                #I wish change my 2D text in the object selected text=adrresult
                UI.messagebox ("@ ; " + adr.to_s + " saved")
              #Menu
              if (not file_loaded?("zEtiquette_config2.rb"))
                  UI.add_context_menu_handler do |menu|
                    if (Sketchup.active_model.selection.length == 1)
              	    menu.add_separator
              	    if ((Sketchup.active_model.selection[0].get_attribute("MyDico", "Name_zone")) != nil)
              		  menu.add_item("Change Zone Name (@" + Sketchup.active_model.selection[0].get_attribute("MyDico", "Name_zone").to_s + ")") { zonename }
              	$VSX = Vsx.new
                file_loaded("zEtiquette_config2.rb")
                  # Interate over the content of the selected group and find the first Text object.
                  # Once we have found that we can change it's text.
                  group = Sketchup.active_model.selection[0]
                  myText = nil
                  group.entities.each { |e|
                    if e.is_a?(Sketchup;;Text)
                      myText = e
                      break
                  myText.text = adrresult
                • P Offline
                  Pauline01
                  i test, thx
                  IT'S, OK. really thx
