Add a text on a point
Re re hello,
I try to add on my group a text.
The text will be contain the string of "adrresult"(see in my code).
I have somes things but...
In my code i want complete after : " #i want to associate the position of my text on a point
#???? position_point_of_my_text = text.point "and
" # text=addresult
#??? textstring = text.text= addresult "thx again...
require 'sketchup.rb' class Vsx @@Obj = nil end def add_etiquette # Get "handles" to our model and the Entities collection it contains. model = Sketchup.active_model entities = model.entities # Create a series of "points", each a 3-item array containing x, y, and z. pt1 = [0, 0, 0] pt2 = [30, 0, 0] pt3 = [30, 0, 17] pt4 = [0, 0, 17] # Call methods on the Entities collection to draw stuff. # new_face = entities.add_face pt1, pt2, pt3, pt4 group = entities.add_group group.entities.add_face(pt1,pt2,pt3,pt4) #i want to associate the position of my text on a point #???? position_point_of_my_text = text.point prompt = ["Zone Name"] val = group.get_attribute("MyDico", "Name_zone") default = [val] result = UI.inputbox prompt, default, "Enter the Zone Name" adrresult = result[0].to_s group.set_attribute("MyDico", "Name_zone", adrresult.to_s) UI.messagebox ("@ ; " + adrresult.to_s + " saved") # text=addresult #??? textstring = text.text= addresult end #Menu if (not file_loaded?("zEtiquette_config.rb")) tool_menu = UI.menu "Tools" tool_menu.add_item("Create zone item") { add_etiquette } $VSX = Vsx.new file_loaded("zEtiquette_config.rb") end -
ok thx
note that the third argument is optional. so you only need to spesofy the point and text. something like:
group.entities.add_text('myText', position_point_of_my_text) -
ok, now i want can change my text contained in a group.
In my second plugin, i have a menu to change "Name_zone" of the object selected.
I can't change the 2D text of my object, because it contained in a group of entities.
In my second plugin i want do this after "#I wish change my 2D text in the object selected
#??? "It's possible or i delete my object and i create a new?
My code who associate my text in a group of entities.
thx again and again. I'am begining...
First plugin:
def add_etiquette # Get "handles" to our model and the Entities collection it contains. model = Sketchup.active_model entities = model.entities # Create a series of "points", each a 3-item array containing x, y, and z. pt1 = [0, 0, 0] pt2 = [30, 0, 0] pt3 = [30, 0, 17] pt4 = [0, 0, 17] coordinates = [0, 0, 8.5] # Call methods on the Entities collection to draw stuff. # new_face = entities.add_face pt1, pt2, pt3, pt4 group = entities.add_group point = Geom;;Point3d.new coordinates group.entities.add_face(pt1,pt2,pt3,pt4) prompt = ["Zone Name"] val = group.get_attribute("MyDico", "Name_zone") default = [val] result = UI.inputbox prompt, default, "Enter the Zone Name" adrresult = result[0].to_s group.set_attribute("MyDico", "Name_zone", adrresult.to_s) group.entities.add_text adrresult.to_s, point UI.messagebox ("@ ; " + adrresult.to_s + " saved") endSecond plugin:
def zonename prompt = ["Name"] val = Sketchup.active_model.selection[0].get_attribute("MyDico", "Name_zone") default = [val] result = UI.inputbox prompt, default, "Enter the Zone Name" adrresult = result[0].to_s adr = Sketchup.active_model.selection[0].set_attribute("MyDico", "Name_zone", adrresult.to_s) #I wish change my 2D text in the object selected text=adrresult #??? UI.messagebox ("@ ; " + adr.to_s + " saved") end #Menu if (not file_loaded?("zEtiquette_config2.rb")) UI.add_context_menu_handler do |menu| if (Sketchup.active_model.selection.length == 1) menu.add_separator if ((Sketchup.active_model.selection[0].get_attribute("MyDico", "Name_zone")) != nil) menu.add_item("Change Zone Name (@" + Sketchup.active_model.selection[0].get_attribute("MyDico", "Name_zone").to_s + ")") { zonename } end end end $VSX = Vsx.new file_loaded("zEtiquette_config2.rb") end -
adr = Sketchup.active_model.selection[0].set_attribute("MyDico", "Name_zone", adrresult.to_s) #I wish change my 2D text in the object selected text=adrresult #??? # Interate over the content of the selected group and find the first Text object. # Once we have found that we can change it's text. group = Sketchup.active_model.selection[0] myText = nil group.entities.each { |e| if e.is_a?(Sketchup;;Text) myText = e break end } myText.text = adrresult -
i test, thx
IT'S, OK. really thx
