    Layout options of transparency
    layout
    3 Posts 2 Posters 5.7k Views 2 Watching
    • F Offline
      fabulafr
      Hello,
      I am using sketchup layout to show some of my works.
      I want to know if it is possible to merge two images imported in layout - as in photoshop - instead of having to put one on another ?
      Is sketchup able to do this or is it too much for it? If so, what kind of programm i should use to show my works?
      • G Offline
        Gjenio
        @fabulafr said:
        Hello,
        I'm doing the same during these days..
        As far as I know there isn't an option to set image transparency in LO. Only fills, strokes and texts can recive transparency. However you can always set your images desired transparency in PS and save them as PNG, than import in LO (that support this kind of files) and overlap them.
        • F Offline
          fabulafr
          Thanks, i will continue with Photoshop and PNG Pictures.
