    Podium light leaks
    extensions
    2 Posts 2 Posters 1.5k Views 2 Watching
    • A
      asirad
      Because my trial version of VRay is end I'm trying SU Podium now. First view was very good and it looks for fast and easy program. Because I wanted compare VRay and Podium I tried to generate the same project in Podium. And result was pretty good except light leaks. In VRay I didn't have problem. To fix the issue I changed default materials, I used 01.OPTIMAlem.xml, default.xml defaultslower.xml files from Podium Forum but light leaks are still there. The model is a bigger file and I don't want searching whole model to find mistakes and where default material is visible. Do you have any tip or trick to fix that? I'm waiting for any suggestion.
      Best Regards
      Asirad
      %(#0040BF)[My Polish Blog ------------
      http://3d.na.wroclaw.pl
      • jim smithJ
        jim smith
        You might try the Podium forum. I did a search for light leaks in the trouble shooting section of the forum and found this discussion:
        http://supodiumforum.websitetoolbox.com/post?id=2187473&highlight=light+leaks
        Might be of some help. I have also found some problems with unusual hot spots and was able to control them by changing the view and/or angle of the sun.
        "Out of clutter find simplicity,
        from discord find harmony,
        In the middle of difficulty lies opportunity"
        Albert Einstein
