    WIP - Twilight Interiors - Update 1-03-10
    12 Posts 7 Posters 1.8k Views 7 Watching
      bytor
      A couple of Twilight Interiors NPR composites - let me know which you prefer. I will be adding some table and floor lamps, and some accessories to the shelves and table tops to get more of a "lived in" look.
      Composite - Style 1
      Composite - Style 2
      Composite - Style 3
      Find the Cost of Freedom.....
      • X Offline
        xrok1
        nice. if i could only pick 1 i'd have to say the middle one. πŸ˜„
        β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
          d12dozr
          I like the 2nd style as it has a good level of detail - the first has lost detail due to the overlaid lines and the 3rd is too "fuzzy", imo. Good work πŸ˜„
          http://goo.gl/f7ooYh
          • F Offline
            FoXar
            I prefer number 3, I do like the fuzzyness πŸ˜„
            • troyhomeT Offline
              troyhome
              definitely number 1. the 3rd is difficult to look at- too blurry.
              IOviz.com
              SU Pro 2024 PC
              • StinkieS Offline
                Stinkie
                These are nice. Number two looks best, IMHO. Care to share some details with regards to the rendering method you used and what the render time was?
                  bytor
                  Thanks for all the feedback guys - I think I prefer the second one as well.
                  hI Stinkie!
                  All 3 images use 2 TwiR images as the base. First 1 was run @ #9 preset - left it cook overnight for 9+ hours = 82 passes. Other was a #7 preset - took 1+ hrs. to run. Then ps work to combine these with multiple overlays of su exports, mostly linework exports. Just the sun for lighting along with a physical sky. I want to start learning to use hdr's - but I am not sure how to be able to keep the well defined shadows that the sun generates.
                  Bytor
                    d12dozr
                    @bytor said:
                    ...but I am not sure how to be able to keep the well defined shadows that the sun generates.
                    If you keep "Sunlight Enabled" checked on, set the Sunlight slider to around 5, and keep Maximum Sunlight Intensity at least 5, you should get well defined shadows with an HDR.
                      dspace
                      @bytor said:
                      All 3 images use 2 TwiR images as the base. First 1 was run @ #9 preset - left it cook overnight for 9+ hours = 82 passes. Other was a #7 preset - took 1+ hrs. to run. Just the sun for lighting along with a physical sky. I want to start learning to use hdr's - but I am not sure how to be able to keep the well defined shadows that the sun generates.
                      Bytor
                      Sun and HDRs are much different stuffs, changing the physical sky for a HDR would be more desirable. (As mentioned above.)
                      But disabling the sun and rendering with HDR only would be quiet a tough job (IMHO) but it can be rewarding if you can get it right.
                      But I'm a little surprise you post only NPRs after cooking for 9+ hrs.
                      Though it would be easier to make improvements from the "raw". πŸ˜„
                      • StinkieS Offline
                        Stinkie
                        Thanks for the info, Bytor.
                          bytor
                          Thanks everyone for the suggestions in working with HDRI - I will be experimenting more in the future.
                          Dspace,
                          My goal was to test some NPR interiors styles - so the PR versions were only ever intended as being a base. That being said - here is the PR daytime image ( 9+ hr.) that I worked from, and also a night version with Artemide Aqua Cil lamps using point lights. No pp on these 2 images.
                          Preset #9 - 34 passes = 3.5 hrs.
                          Preset #9 - 82 Passes = 9+ Hrs.
                            dspace
                            I think you did a great job when rendering is concern. πŸ‘
                            Without pp the images are little on the dark side.
                            Keep up the good work. πŸ˜„
