    Wire frame to pipe?
    4 Posts 3 Posters 638 Views 3 Watching
    • P Offline
      pixelmonkey380
      need some help, as i'm not sure if this can be automated or not.
      have a wire frame, almost all square edged, and quite complex. i'm wanting to know if there is an automated way to create a pipe or tube that follows the entire wire frame.
      clean edges a plus! prefer not to have pipe inside of pipe, to save some file space.
      the model i'm working with is located here
      open for suggestions.
      chris<pixelmonkey>:D
      • EscapeArtistE Offline
        EscapeArtist
        Lines to tubes?
        http://forums.sketchucation.com/viewtopic.php?f=323&t=12354&start=0&st=0&sk=t&sd=a&hilit=lines+to+tubes
        It will not intersect and clean up, you'll need to do that yourself.
        • P Offline
          pixelmonkey380
          @escapeartist said:
          Lines to tubes?
          worked great!
          now to work on cleaning edges.
            PipeAlongPath with inner/outer radius== or TubeAlongPath will make a 'tube' along a set of connected edges BUT they can't branch - however, the 'ends' junctions are tidied up.
            You'd need to selected a number of connected edges/curves [end-to-end] and use the tool several times to make a partially tidied frame. Lines2Cyl etc will make all selected edges into separate cylinders...
            Some manual tidying up will be inevitable with branching forms...
