    [Plugin] Edge Tools
    211 Posts 74 Posters 294.5k Views 74 Watching
      Sorry about replacing the Divide Face video is a poorer quality YouTube video, but I ran out of bandwidth on Screencast and I did not have the original video.
      • pilgerP Offline
        pilger
        Hey thom!
        I wonder if the simplify curve bit work with closed curves or even surfaces. I find myself in a position in which i imported geometry from a DWG and it left me with some insanely segmented edges. I'm trying to find a method to simplify this thing which complies with the Human Rights.
        I've uploaded a small sample to make it clearer.
        Thanks in advance.
        EDIT:
        Found a neat SimplifyCountours.rb script right on the SketchUp repository (http://sketchup.google.com/download/rubyscripts.html). Silly me.
        I figured i should post it here in order to help whoever has a similar issue, since it's somehow related to the plugin subject.
        I'll be keeping your plugin though, thom. It's pure juice. Keep it up!
        Segments from imported geometry
          I realised last week that it did not work for closed curves. But this I should be able to make work.
          However, it will not work with faces attached.
          • pilgerP Offline
            pilger
            That wouldn't be much of a problem. There's a pretty good Make Face plugin around (i don't remember who wrote it, though).
            I'm having some difficulties in using that Simplify thingy i've found as it uses angles to do the dirty job and not the neat Rammer-Douglas_Peucker algorhithm. πŸ˜•
              Yea - it's why I was looking for a different algorithm as I found that Simplify didn't preserve the overall shape as well.
              From your screenshot it looks as though you have a lot of criss-crossing curves. That leads to problems with any curve simplification algorithms.
              In my DP implementation I pre-process the selection to locate curve segments. A curve segment is only valid if it doesn't have faces connected or forks. Anything that doesn't fit the requirements is silently ignored.
              • pilgerP Offline
                pilger
                Indeed, i realise the crossing is a bit of a problem. However, i separated them all in groups (which is basically double clic and group, being a fairly easy task) so i guess that wouldn't get much in the way.
                  hm... I guess it could be made into an option to consider a curve segment to be between forks...
                  Adding to Experiment list.
                    Version 1.1.2
                    Important Bug Fix!
                    Fixed incorrect lengths for Divide Face tool.
                      Perfection is not for this world πŸ˜‰
                      • K Offline
                        keyston
                        Hi Thomtom,
                        First, thanks for your hours spent making all these plugins. its a wonder google dont take some onboard for future su releases.
                        I not very technically inclined when it comes to 3d terminology, just want to ask about importing terrain from google earth (get current view ), If I get a few views all slightly overlapping,then explode and toggle terrain, I get holes and overlaps and mess.
                        Which one of your scripts is best to clean this up? Edge tools or cleanup rb?
                        Also in su 8 get current view is no longer in the google toolbar?
                          shoeb_cars
                          RESPECT ++
                          u saved my life again...TQ very much
                            Version 1.1.3
                            Important Update! Now handles curves the forms loops.
                              rv1974
                              Damn how could I miss it? Excellent! With this set of tools you came very close to the one of the biggest hemorrhoids in my workflow- the acad generated arcs\polylines\curves. They typically overlap, cut each other, have different segment length and stray ends etc. If only you could make something in this direction πŸ˜‰
                              kkk.skp
                                Overlapping curves that intersect each other is troublesome. It's something that should be corrected in Autocad before importing as it'd be difficult to separate them afterwars. ("Garbage in garbage out")
                                As for the curve segments - Fredo's Bezier Curve tool let you convert curves into parametric curves you can adjust - can be used to interpolate I think. Maybe his plugin could be automated to process a set of curves?
                                  bentleykfrog
                                  Awesome toolset, would be nice if divide faces preserved the edges soft, smooth and hidden properties though.
                                  thanks thomthom
                                    thanks thomthom
                                    Good idea. I have an update coming up very shortly. Though it won't make it for that, but I'll be on my todo list. πŸ‘
                                      Version 2.0.0
                                      • Bug fixes
                                      • Toolbar
                                      • Close Gaps
                                      • Erase Stray Curves
                                      • srxS Offline
                                        srx
                                        Thank you, thank you, thankyou...
                                        www.saurus.rs
                                          Version 2.0.1
                                          • Fixed minor issue where the plugin might throw an error if another plugin hadn't already loaded TT_Lib2.
                                            dedmin
                                            • 10
                                            • 11
                                            • 3 / 11
