    [Plugin] Edge Tools
    211 Posts 74 Posters 294.5k Views 74 Watching
    • pilgerP Offline
      pilger
      Indeed, i realise the crossing is a bit of a problem. However, i separated them all in groups (which is basically double clic and group, being a fairly easy task) so i guess that wouldn't get much in the way.
        hm... I guess it could be made into an option to consider a curve segment to be between forks...
        Adding to Experiment list.
          Version 1.1.2
          Important Bug Fix!
          Fixed incorrect lengths for Divide Face tool.
            Perfection is not for this world πŸ˜‰
              keyston
              Hi Thomtom,
              First, thanks for your hours spent making all these plugins. its a wonder google dont take some onboard for future su releases.
              I not very technically inclined when it comes to 3d terminology, just want to ask about importing terrain from google earth (get current view ), If I get a few views all slightly overlapping,then explode and toggle terrain, I get holes and overlaps and mess.
              Which one of your scripts is best to clean this up? Edge tools or cleanup rb?
              Also in su 8 get current view is no longer in the google toolbar?
                shoeb_cars
                RESPECT ++
                u saved my life again...TQ very much
                  Version 1.1.3
                  Important Update! Now handles curves the forms loops.
                    rv1974
                    Damn how could I miss it? Excellent! With this set of tools you came very close to the one of the biggest hemorrhoids in my workflow- the acad generated arcs\polylines\curves. They typically overlap, cut each other, have different segment length and stray ends etc. If only you could make something in this direction πŸ˜‰
                    kkk.skp
                      Overlapping curves that intersect each other is troublesome. It's something that should be corrected in Autocad before importing as it'd be difficult to separate them afterwars. ("Garbage in garbage out")
                      As for the curve segments - Fredo's Bezier Curve tool let you convert curves into parametric curves you can adjust - can be used to interpolate I think. Maybe his plugin could be automated to process a set of curves?
                        bentleykfrog
                        Awesome toolset, would be nice if divide faces preserved the edges soft, smooth and hidden properties though.
                        thanks thomthom
                          thanks thomthom
                          Good idea. I have an update coming up very shortly. Though it won't make it for that, but I'll be on my todo list. πŸ‘
                            Version 2.0.0
                            • Bug fixes
                            • Toolbar
                            • Close Gaps
                            • Erase Stray Curves
                            • srxS Offline
                              srx
                              Thank you, thank you, thankyou...
                              www.saurus.rs
                                Version 2.0.1
                                • Fixed minor issue where the plugin might throw an error if another plugin hadn't already loaded TT_Lib2.
                                  dedmin
                                    Version 2.0.2
                                    • Fixed minor namespace reference issue.
                                      dedmin
                                      πŸ‘ πŸ‘ πŸ‘ πŸ‘
                                        rv1974
                                        Thank you for all february 05 goodies.
                                          @dedmin said:
                                          [attachment=0:375j5dqr]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:375j5dqr]
                                          Thanks for reporting that. I was a bit quick to release the last fix so I forgot to test it before shipping. 😳
                                            dedmin
                                            @thomthom said:
                                            @dedmin said:
                                            [attachment=0:1l1j5985]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:1l1j5985]
                                            That is the minimum we can do to respect and help plugin's writers! β˜€
                                            • 11
                                            • 3 / 11
