    Export issue
    5 Posts 3 Posters 1.0k Views 3 Watching
    • J
      jerrard
      hi.
      I am trying to export a 3d .dxf or .dwg file to use in vectorworks 11 but I get a window that says 'exporting model' then immediately a window that says skp2acad AutoCAD export audit : OK This hangs forever and if I click ok on the export audit window everything stops. Any thoughts?
      (Mac os 10.5.8, sketchup 7)
      thanks
      • R
        remus
        if your only having the problem with this file you could try copy and pasting all the geometry in to a new file.
        • J
          jerrard
          no - I've tried several files and downloaded a new copy of sketchup - same issue.
          • D
            driven
            hi jerrard,
            I find skp_to_dxf(dot)rb better then SU export on the mac, I also use tt_cleanup(dot)rb first.
            if I still have a problem I export a dae, clean it in Meshlab then save as dxf from there.
            john
            SketchUp to DXF STL Converter
            Authors: Nathan Bromham, Konrad Shroeder
            • J
              jerrard
              thank you john, that really helped
              cheers,
              jerrard
