    Export issue
    5 Posts 3 Posters 904 Views 3 Watching
      jerrard
      hi.
      I am trying to export a 3d .dxf or .dwg file to use in vectorworks 11 but I get a window that says 'exporting model' then immediately a window that says skp2acad AutoCAD export audit : OK This hangs forever and if I click ok on the export audit window everything stops. Any thoughts?
      (Mac os 10.5.8, sketchup 7)
      thanks
        remus
        if your only having the problem with this file you could try copy and pasting all the geometry in to a new file.
          jerrard
          no - I've tried several files and downloaded a new copy of sketchup - same issue.
            driven
            hi jerrard,
            I find skp_to_dxf(dot)rb better then SU export on the mac, I also use tt_cleanup(dot)rb first.
            if I still have a problem I export a dae, clean it in Meshlab then save as dxf from there.
            SketchUp to DXF STL Converter
            Authors: Nathan Bromham, Konrad Shroeder
              jerrard
              thank you john, that really helped
              cheers,
              jerrard
