    Imported autoCAD
    9 Posts 5 Posters 895 Views 5 Watching
      me_nikola
      ok, so this is my problem:
      imported autoCAD plan into SketchUp, but it has only lines no faces,
      do I really have to draw all the faces manually? The file in CAD was perfect
      snapping faces goes without a problem and very quickly but it is the plan of the small town!
      I will need a lot of time for this no-brain job just making faces from lines, I try drawing a big
      rectangle over it and intersect it but no good 😞
      Do I really have to do this face by face?
      Please help!
        remus
        try this: http://www.smustard.com/script/MakeFaces
          me_nikola
          YES, it works PERFECTLY!!
          you saved me hours of meaningless brainwashing wok πŸ’š
          THANK YOU
            OR: drape the lines onto a flat face
            OR try this plugin by Thomthom (although that is best when there are separately standing buildings).
              remus
              Glad it worked as hoped πŸ‘
                aylossaaa
                I'm trying to import autoCAD into sketchup pro (mac) yet every time i do, the program closes "unexpectedly". can somebody please tell me what i'm doing wrong or whats wrong with my SUp?
                • AnssiA Offline
                  Anssi
                  @aylossaaa said:
                  What you can try:
                  Check that you have the latest bug fix version of SketchUp Pro
                  Delete or rename your SketchUp preferences file (the regular Mac users here can tell you where to find it)
                  Repair your disk permissions
                  Anssi
                    aylossaaa
                    disk permission is fine. and i deleted my preferences file (didn't know what to rename it to exactly) , and nothing, still the same.
                    but i didn't know how to check for the latest bug fixes.
                    • AnssiA Offline
                      Anssi
                      Aylossaa,
                      What is the source of your DWG files? Is it in a format that SU can recognize (SU can import version 2007 files and older)? Can you post a problem DWG for us to check?
                      Anssi
