    Help with Style...
    3 Posts 2 Posters 1.0k Views 2 Watching
    • W
      Windknot
      I like the style of this sketchup model, how would I achieve this or is there a style out there I can upload that will result in a similar look?
      http://img521.imageshack.us/img521/9606/frontci.jpg
        In the Window menu choose 'Styles' and this will appear......
        Select the 'Edit' tab as you see above and here you can change which parameters you would like to see or not see.
        I checked the 'Extension' box and set it to 10 to get this result...
        Hope this helps
        • W
          Windknot
          Thanks, I forgot about editing the extension.
          http://i182.photobucket.com/albums/x178/CCG_TX/PatioCoverroofnotg.png
