    Car Shock Absorber
    16 Posts 10 Posters 1.1k Views 10 Watching
      Luis Esteves
      Good day everybody,
      Here's a render just for fun. I was learning how to build springs, and I finally did a shock absorber.
      The modeling is not perfect, but I like the result (anyway I have to improve it).
      Car Shock Absorber
      • CarrozzaC Offline
        Carrozza
        Hi Luis, I would be very interested to know how you did model the spring!
        Great rendering, by the way; V-Ray is the best.
          Luis Esteves
          Hi Carrozza,
          Modelling a spring is not difficult.
          I simply found the solution on Google SketchUp Warehouse. There is a lot on good stuff there.
          The link : http://sketchup.google.com/3dwarehouse/details?mid=3277705e558ca6dcd0341d9d8a035ecc
          Spring.skp
          • CarrozzaC Offline
            Carrozza
            Thanks a lot for pointing me to Google Warehouse: it deserves a better exploration.
            • ely862meE Offline
              ely862me
              [flash=425,344:1dupbml4]http://www.youtube.com/v/H1IO2f1xvd0&hl=en_US&fs=1&[/flash:1dupbml4]
              a lot easier 😉
              Elisei
              Elisei (sketchupper)
              Come and See EliseiDesign
                You show the easiest manual method to do this, but you could use the Helix and the PipeAlongPath [or TubeAlongPath] Rubies to make it even more easily ?
                  Luis Esteves
                  Thank you TIG, I will try these scripts.
                  ely862me : nice and faster way to do it ! 😄
                  Thanks.
                    dolphus
                    Your Shock Absorber looks very good nice render as well, i also use the helix and tube along path rubies very easy and accurate well done 👍
                      Luis Esteves
                      Thank you dolphus for your reply. I will try these scripts tonight.
                      • mitcorbM Offline
                        mitcorb
                        May I ask if you used any scale techniques, or is this just by eye?
                        • stefanqS Offline
                          stefanq
                          Magnífico! What render engine did you used , Luis?
                            Luis Esteves
                            Thanks for your comments.
                            @stefanq : The scene has been rendered with Vray for Sketchup Trial (maybe I will buy it).
                            @mitcorb : I used basic forms (cylanders, cubes and curved lines).
                            • olisheaO Offline
                              olishea
                              excellent 👍
                              oli
                              • david_hD Offline
                                david_h
                                Its so beautiful, it's a shame that it ends up on the bottom of some car. It needs to be out there!
                                • ely862meE Offline
                                  ely862me
                                  😆 and still they do good job down there
                                    meak
                                    bravo,
                                    good job very realistic!
