    Viewport scale changes on update
    layout
    2 Posts 2 Posters 1.2k Views 2 Watching
      marko
      I have a problem with my SU models in layout changing scale when I update the links.
      I've inserted views of my model into LO like a floor plan and elevations and set the scale of these to say 1:50, but when I update the model reference the scale changes to some random scale slightly different to 1:50. This is frustrating because every view then requires me to re-set the scale and move the view to align with my LO notes & dimensions every time I change my SU model.
      Is there a way to make sure the SU view in LO stays exactly the same when updated?
      i should have thought of something clever to write here...
        bjanzen
        Do you have "Preserve Scale on Resize" checked (it's in the SketchUp Model Inspector's View tab)? I just tried it with the standard views with ortho projection, and when I changed the scale on each scene, it added "(Modified)" in front of each of the scene names, but did NOT change the scaling when I changed geometry and materials.
        I may not be doing thing exactly the way you are, so here's what I did: I created a simple SketchUp model with 7 scenes, each with Camera->Parallel Projection, and the 7 views you get from Camera->Standard Views. I sent this to layout, and created 7 pages, each with a page matching the name of the view (top, bottom, etc...) and changed the scale to 1/4" = 1' (1:48) on each page. Preserve scale on resize was checked.
        I then went back to SketchUp and changed a few things (geometry of building, materials, etc...), updated a scene, saved, then back to LayOut and updated the skp model reference. Everything stayed the same for me. More info if you can, because if this is happening, I can see how it would be a pain.
        b
