    Problem with Joint Pushpull
    4 Posts 4 Posters 643 Views 4 Watching
      ryaneiferd
      Hey Guys,
      Can anyone tell me what this error message means:
      Error Loading File jointpushpull.rb
      undefined method `get_last_state' for nil:NilClass
      It doesn't seem to effect the tool, but wanted to make it go away.
      Cheers!
        Edit the File and Find Line ~2349
        status = @tlb.get_last_state
        Add onto the end of it thus, to read
        status = @tlb.get_last_state if @tlb
        The variable @tlb will point at the 'toolbar' - it is initially set to nil and so the status setting fails until it's set to something... this way status is tested and set only after @tlb is found to be something other than nil...
        • H Offline
          hrland
          I have the same problem and when I made the change it won't let me save, tells me "access denied". Any way to get this fixed? Thanks.
          • fredo6F Offline
            fredo6
            The problem derives from a wrong installation: i.e. For whatever reasons, the image files JPP_....png icon files cannot be found in the JPP_Dir_xx directory.
            I suggest you check if the files are present.
            Fredo
