    Easy method to Make Cartoon drawing
    4 Posts 4 Posters 622 Views 4 Watching
      babboi
      what is the easiest method to export a Vector cartoon style hidden line drawing?
      or alternatively (not preferred) a render of just the line work with all white faces.
      Please go step by step as I am a new user.
      best,
      dave
        d12dozr
        Super easy πŸ˜„ on your Menu bar, go to View > Face Style > select Monochrome.
        Then go to File > Export > 2D Graphic...
        Before exporting, I would save the view as a Scene so you can come back to the exact view if you ever make changes and need to export again...View > Animation > Add Scene
        http://goo.gl/f7ooYh
        • AnssiA Offline
          Anssi
          d12dozr,
          Your method doesn't work if you have set your default face colour to other than white.
          View>Face style>Hidden line is the way to go...
          Anssi
          • brodieB Offline
            brodie
            Yeah, hidden line is the way to go. You'll also have to go into your style editor menu and turn off the sky/ground and change the background color to white though.
            -Brodie
