    OnKeyDown repeat parameter problem
    21 Posts 8 Posters 4.8k Views 8 Watching
    • tbdT Offline
      tbd
      giving this code (easy to paste in Ruby console):
      class T;def onKeyDown(key, repeat, flags, view);p repeat;end;end;
      Sketchup.active_model.select_tool T.new
      I get only 1 (single press) and never 2 (key hold down) on Windows compared with Mac where it works as expected.
      tested on 7.1.6087 with Plugins dir empty. same problem in 6 as well.
      anyone had the same problem ?
      SketchUp Ruby Consultant | Podium 1.x developer
      http://plugins.ro
        I've not used that parameter before. But I do see the same. 😞
        • Chris FullmerC Offline
          That API states:
          V6: There is a bug on Windows where the typematic effect does not work. Typematic effects work fine on a Mac.
          http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#onKeyDown
          I guess it has not been fixed for v7 or 7.1 too then?
          All my Plugins I've written
          • tbdT Offline
            tbd
            seems that is stuck in v7 as well. not good.
            I plan to make SU Ruby API page that contains all of our findings, code snippets and examples using the searchable interface from Rails API as I am wasting too much time with current google's implementation (due page jumping and incorrect data)
            http://plugins.ro
              Any way to contribute? Got lots of into in this thread: http://forums.sketchucation.com/viewtopic.php?f=180&t=17047
              • tbdT Offline
                tbd
                I plan to have it on github/bitbucket and also a web module for those that want to contribute and don't want to get 'dirty' with version control systems.
                There will be also a downloadable version for speed maniacs like me πŸ˜‰
                and that thread is the first on my list of sources. thanks for work involved.
                http://plugins.ro
                  Wouldn't a temporary 'fix' be [without the need for other perhaps platform specific solutions], to ask the user to keep rapidly pressing a certain modifier key [key-down/key-up] - that way you can check for keyDown and keyUp actions, and then you'd know what they are doing: the final keyUp would exit after a set short-time without a keyDown occuring ?
                  Exactly why do you [we] need this specific action anyway ❓
                    Or use a timer that starts on keydown and stop on keyup - accounting for the initial delay for the repeating to trigger. And I think the repeat interval isn't linear...
                    • tbdT Offline
                      tbd
                      I plan to use it for a tool to increase/decrease radius of tool action based on VK_UP/DOWN press. on Mac it works great, on Windows you need to press,release,press,release - it kills the fun πŸ˜‰
                      I should try the timer solution and see the correct 'amount' of delay for a typematic effect πŸ˜‰
                      http://plugins.ro
                        Think the system default is stored in the registry somewhere. If you want to try to match that.
                          mtalbott
                          TBD,
                          Were you, or anyone else, able to create a good work-around for the repeat bugg on windows? I was wondering myself how best to set a timer to determine a key being held down.
                          I am using this on a fun script that makes navigating a model more like a FPS.
                          -Mike
                            There's an issue with SU's timers - the interval is rounded down to whole integers. So anything below 1.0 will turn into 0.0 turning the timer into an instant loop.
                              mtalbott
                              Thanks ThomThom,
                              That's good to know. So I'm still lost to how to create a key holding function on windows. I was hoping to be able to start a loop on the onKeyDown and then have onKeyUp break the loop. Unfortunately, once the loops starts sketchup seems to be too busy working on that to notice that I've released the key. Any ideas on how to break the onKeyDown loop when a key is released?
                              -Mike
                                hm.. well, using a timer might work. Even though its bugged. It might just be that it allow other stuff to execute before it restart the iteration. ??
                                • Dan RathbunD Offline
                                  Dan Rathbun
                                  -Mike
                                  Perhaps:
                                  (1) Try executing the onKeyDown loop in a subthread, so that the main thread can still 'trap' the onKeyUp event. You would probably need your Tool to have an boolean instance var, like @mykeydown, set to true by the onKeyDown event callback method, BEFORE you go into the loop; and for example the loop condition might be:
                                  while @mykeydown do ...[code]... end
                                  ..then the onKeyUp event callback method would set @mykeydown=false, and the loop should exit on the next pass.
                                  The big trickis that you need the call to yourTool.onKeyDown to return (while still running the loop in a sub-thread,) so Sketchup can do other things, including redraw the UI, and watch for the release of the keys, so it can call the yourTool.onKeyUp method.
                                  I'm not here much anymore.
                                    mtalbott
                                    big trick is that you need the call to yourTool.onKeyDown to return (while still running the loop in a sub-thread,)
                                    That's great advice. I was missing that big trick part. I think I inadvertenly figured that out but in a slightly different way. I was having trouble getting the view to refreash so I ending up having the onKeyDown create an animation object which contained the main loop in the Nextframe def. To my suprise, it worked! I used the onKeyUp to cancel out the animation object.
                                    I've attached the plugin if anyone is interested. It's just a different way to walk around a model. more like a video game. I find the walk tool hard to use and pan/orbit is great for modeling but it's not as emersive as a video game style navigation.
                                    controls are:
                                    keypad to walk forward/back, step left/right.
                                    move mouse to look around/ turn.
                                    Ctrl to jump (just for fun).
                                    esc to reset it if it gets all messed up (which sometimes it does)
                                    select another tool to exit
                                    This is only my thrid script that I've mostly completed so I apologize for what is probably terrible coding. there are definately a few bugs in it but this is about as far as my skills can get me.
                                    The major remaining issue with no solution I can think of is that in a videogame you can just move the mouse endlessly to the left and right to turn. Unfortunately, In sketchup you have limited screen space to move the mouse in. If there was a way to get around that, I'll be really excited about this plugin.
                                    Thanks again for the help. This is a great community,
                                    Mike
                                    First Person "Sketchuper"
                                      Dan Rathbun
                                      (1) What about trapping the left and right mouse buttons to turn, rather than moving the mouse?
                                      (2) When I think of video games (the only one I play,) I think of MS Flight Simulator. This plugin would be great for my MS FlightStick. Left, right, forward and back on the stick moves. Twist (rudder left/right,) would pivot. And the rocker switch (often used for elevator/pitch trim,) would be up and down, for going up and down stairs. Other buttons could do other things such as interact with Dynamic Components (like open a door.) Would need to figure out how to write a Ruby binding to the USB game controller interface.
                                      • renderizaR Offline
                                        renderiza
                                        @dan rathbun said:
                                        -Mike
                                        Perhaps:
                                        Can someone explain this with an example code so I can understand better. What is a subthread? I can't figure out how to solve this "Typematic effects" bug in windows. Please Help
                                        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                                          Dan Rathbun
                                          Well threads do not work well in embedded Ruby.
                                          Use a UI.start_timer block, which may create a native thread on the C++ side of the SketchUp engine.
                                            It doesn't create a thread. If the timer block do a lot of time consuming things it blocks everything else until it's done.
                                            • 1 / 2
