    Putting image on background
    3 Posts 2 Posters 406 Views 2 Watching
    • H Offline
      homie
      I am trying to put a jpeg image onto a surface which is exactly the same size as it.
      I've heard that the only way to do this is by making it into a texture. However, when I do this the image is offset from the top and left and gives the appearnce of tiles. The image is the correct size but not in the correct place.
      If anyone could help me with this I would be very grateful πŸ˜„
      Thanks,
      homie
        Right click the face, Texture -> Position
        Use the texture gizmo to adjust your texture as fit.
        • H Offline
          homie
          Yep, that solved it πŸ˜„
          Thank you very much πŸ˜„
