    Tools and keys pressed
    4 Posts 3 Posters 424 Views 3 Watching
      I got a tool where the VCB is enabled.
      If I activate it an type "s" or "e" then I activate the Scale or Eraser tool.
      But if I type a digit first, then subsequent "s" or "e" won't trigger their tools. ("5sesesesese" <- this does not trigger any tools)
      On the other hand, if I type "5f" then the Offset tool wil trigger when I type "f" - even though I typed a digit first. Inconsistent with Scale or Erase.
      Can anyone explain this?
      Also, is there any way to suppress keys being pressed when your tools is activated to trigger other tools?
      • F Offline
        flyashy
        erm..
        could be that the vcb considers the 's' in 5s as segments and thus does not consider the following keypresses? i don't know about the 'e' though..
          All numbers, points, commas and brackets etc and the characters s, x and / are 'protected' characters. The last three when used after numbers 'always', and when used before numbers IF you have NOT redefined them to a Shortcut key - e.g. using x for xray-mode would NOT be a good idea as Move+Ctrl copy x5 will turn on xray mode, whereas 5x arrays the copy 5 times. These last three characters are used in setting arc segments and array copying. Incidentally you could set 2 to be a Shortcut key BUT every time you pressed 2 as part of a length in the VCB the Shortcut-Tool would trigger - therefore some keys should never be used for Shortcuts!
          Thus if you use one of these 'protected' characters in your Tool's VCB text they are ignored, especially if they are after a number.
          If you use m, cm, mm, ", ' after numbers then these too are ignored as Shortcuts as they could be lengths.
          Otherwise typing 2m wouldn't be taken as 2 meters but Move which would make life impossible !
          All other character are read as VCB commands if they are anywhere in the VCB text!
          For example, use the Line tool and type in 3m or 3cm or 3mm and you gets lines of those lengths; also typing 3' gives a 3foot long line, or 3" gives a 3inch long line: BUT typing 3ft jumps out of Line to Followme then Tapemeasure [OR whatever your shortcuts are set to] and 3in doesn't work for inches either!
          So to recap you can only safely accept certain characters in the VCB AFTER numbers as the user might have [ill-advisedly] remapped some like x or s to shortcut to other tools. These characters are s, x, /, ', ", m, c[m], m[m] and , as separators - I have also safely used a : as a separator in my 2D Chamfer tool. The text 'pt' and <> brackets are also potentially allowed to set relative co-ordinates - for example, to set the end point to a location 1.5 points right and 2.3 points down from the start point, type <1.5pt,2.3pt>. For polar ^ is potentially allowed as a start character thus ^45,10m for 45 degrees,10m. To set absolute co-ordinates from the ORIGIN you can also use [10",2"] so square brackets [] are also potentially allowed ?
          I don't think you can 'switch off' the VCB character recognition, IF you want to use it to take lengths etc, BUT you can switch of the VCB completely, with this def, within your Tool using
          def enableVCB?
            return false
          end### or return true to switch it on
          You can then watch for user key-presses [Tool.onKeyDown or Tool.onKeyUp] within your own Tool without risk of the VCB taking something the wrong way... πŸ˜•
            "degree" seem to work as input as well.
            Off is the default.
            Problem is that the shortcuts still trigger.
            I was enabling the VCB in hopes it'd prevent that and catch the keys... πŸ˜•
            I've even tried returning false on the Key events - in hopes to suppress the keys being sent to the rest of the system - like you do in HTML + Javascript. But no luck there either.
            Bugrit, millennium hand an' shrimp!
            Anther idea crash and burns. 😞
