    Projections extension - Extrude lines with vector problem
    7 Posts 6 Posters 893 Views 6 Watching
    • PixeroP Offline
      Pixero
      Am I the only one that is having problems with getting "Extrude lines with vector" to work?
      (The v2 + update) the v6 (older?) works but have less tools.
      Is there a known compability problem with any other script?
        Some tools were consolidated into the toolbar projection.rbs in Plugins/Projection/ folder that's encrypted and contains all of the stuff - loaded by projection_extension.rb.
        Perhaps you have an older 'loose' rb in Plugins that's also in this rbs and needs removing so that it doesn't load and clash with the newer one ?
        If you find extrudeline.rb in Plugins or something like that, then try renaming it with a .txt suffix and it won't load and mess up the others ?
        • EarthMoverE Offline
          EarthMover
          It seems to work fine for me. I also have the older extrudelines plugin installed and use the both for different situations. I find the older one to work better in most situations as it snaps to the directional axis whereas the projection tool extrude lines doesn't.
          Content Creator at Skapeup
          • PixeroP Offline
            Pixero
            Removing everything projection related and reinstalling seem to have fixed it.
              Moved the thread to the Developer's forum. We have reorganized so that the Plugin section is only a list of plugins you can download and use. πŸ€“
                torrescravo
                hello to all I would like to have the plugin for older extrudeline, selecting one that aligns call the plugin and a window appears asking between the size of the height "Z" thank you for your attention. I am in Brazil and use the google translator to write this question. will be that you could help me with this problem.
                • Chris FullmerC Offline
                  [Portuguese]
                  Acho que talvez vc esta pensando em meu plugin chamado "Three Line Tools" (tres utilidades de linhas (mais ou menos)). Pode acha-lo aqui:
                  http://forums.sketchucation.com/viewtopic.php?f=323&t=16923
                  e o plugin esta ao baixo do primeiro "post" meu. E si nao Γ© aquele plugin qeu esta buscando, fica a vontade de explicar em portugese como funciona o plugin que esta procurando πŸ˜„ E desculpa si meu portuguese esta rui, sou da California e foi dez anos atraz que eu vivi em brasil.
                  Chris
                  [English]
                  I think you are looking for my Three Line Tools plugin. Here is the link:
                  and the plugin is at the bottom of my first post. And if that is not the pluing you are looking for, feel free to explain in portuguese how the plugin you are looking for funtcions. And sorry if my portuguese is horrbile, I'm californian and it was over 10 years ago that I lived in Brazil.
                  Chris
                  All my Plugins I've written
