    [Plugin] Teapot
    37 Posts 16 Posters 39.7k Views 16 Watching
      I realised SketchUp was missing a very important basic primitive:
      Martin Newell's teapot!
      Parametric mesh generated from bézier patches using Martin Newell's tea-set dataset.
      Access From:
      Draw -> Teapot -> ...
      Create Primitive
      Choose the primitive to create from the menu or toolbar. A window with options will appear:
      After you click Ok you can position and orient the primitive. (Note: Preview is always a simplified version.)
      Edit Primitive
      Select an primitive and use the appropriate menu or toolbar button to access it's parameters.
      (Example: To edit a teapot; select the teapot and click the teapot button in the toolbar.)
      Examples
      1. Type in 0 under Segments to create a mesh from the raw control points.
      2. 6 Segments teapot with no smoothing
      3. 16 Segments teapot with soft + smoothing
      4. Original Scale will scale the mesh by 1.3 in the Z axis o match Newell's original dataset. The Standard set is a result of the early adopters was using monitors with non-square pixels.
      5. Newell's Teacup
      6. Newell's Teaspoon
      7. Choose what parts to generate. Option to triangulate etc.
      History Lession
      To be true to the original dataset; don't generate the Bottom and set Scale to Original.
      [flash=400,300:1715yr1i]http://vimeo.com/moogaloop.swf?clip_id=7439194&server=vimeo.com&show_title=0&show_byline=0&show_portrait=0&color=00adef&fullscreen=1&autoplay=0&loop=0[/flash:1715yr1i]
      Video by Unfold
      Known Issues
      • Some times very small faces might not be created. Especially for the teaspoon.
      • Teaspoon has a couple of vertices that doesn't seem to have been created properly. Not sure if it's the dataset or SU's problems with small faces.
      • Faces reversing. I experienced once just before releasing this plugin that some faces came out reversed. I wasn't able to reproduce or determine the cause of that.
      http://sketchucation.com/resources/pluginstore?pln=tt_teapot
      Requirements
      • Google SketchUp's Bézier plugin: http://download.sketchup.com/downloads/downloads/rubyscripts/bezier.zip
      • Chris FullmerC Offline
        That's great Thom, I am sort of surprised that SU didn't include this. It is the most famous 3d object in the world. Thanks for writing it,
        Chris
        All my Plugins I've written
        • EarthMoverE Offline
          EarthMover
          Very cool! Where's the button to make it dance?
          With 8 segments
          Content Creator at Skapeup
          • MALAISEM Offline
            MALAISE
            Nice, couldn't you modelize bottle of wine and glass too ? 😆
            MALAISE 👍 ( of course French ! 💚 )
            • urgenU Offline
              urgen
              .... 😆 👍 ....THANKS!
              --pupil forever...------
              • PixeroP Offline
                Pixero
                Yees! Thanks. 🤓
                  Well, This whole project has got me thinking about patch modelling in SketchUp. So maybe you will be able to create your own parametric patch objects eventually. 😉
                    Be fun if you used one of the animation plugins and made one! 😄
                    Make the all the 2D-face-me Googlers dance around as well. 😆
                      Cool plug! ☀
                      Original Image by EarthMover 😉
                      Here colors modified & Text added 😆
                      • FrederikF Offline
                        Frederik
                        Fun... 👍
                        Cheers
                        Kim Frederik
                        • plot-parisP Offline
                          plot-paris
                          thats great Thomthom! at last SketchUp is definitely and undeniably a fully professional modeller. no one can question that anymore now 😍
                            Updated to make it work under SU6.
                              driven
                              TeaCup_Glass.jpg[quote="MALAISE"]Nice, couldn't you modelize bottle of wine and glass too ? :lol:
                              The teacup (primitive) is quickly a wine glass, so now if you can make the Champagne bottle we can 'CHEERS' thomthom appropriately.
                              Great concept, well executed,
                              as a thought, can this be modified to be a 'make_ primitive .rb' with all the whistles and bells for all those incredibly repetitive, but slightly different components I keep making?
                              cheers
                              john
                                What bells and whistles is that?
                                I only used the existing dataset that was available for the teaset. But if you have bezier patch data it's easy to add more objects.
                                  driven
                                  the UI, specification ability and progress report/warning.
                                  I found a python script for hypyocoloids that I want to use in SU but have no idea of how to implement.
                                  On seeing this, I thought having a hypyocoloids primitive would be very useful for myself and maybe one other person on the planet.
                                  I haven't got anything on my mac that's been able to even test the py script yet.
                                  I have scratch built one to try in SketchyPyhsics, but they need to be so accurate to work, I haven't succeeded (by using dimensioned geometry) yet.
                                  I don't know if this [py] script uses bezier patches as I don't know what they are. I'll attach a zip so you can to have a look, maybe...
                                  cheers
                                  love the teaset.
                                  it was zipped on a mac.
                                    "hypyocoloids"? I find nothing when I Google that.
                                      driven
                                      I have other links but on my way out just now so will check back and upload later if you want them
                                      cheers john
                                      • simon le bonS Offline
                                        simon le bon
                                        Hi tmtm
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/an_cup.gif
                                        Are you introducing a new family of Rubies? something like "Nonsense Tools 😆
                                        I positively love it!
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/tmtm_TeaPot002_450.jpg
                                        Christmas Tea:
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/tmtm_TeaPot001_450.jpg
                                        You are our very "english" martian of the place
                                        http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/Alien114.gif
                                        😄 simon
                                          simon le bon
                                          we know Photon Mapping
                                          Do you know "TeaPot Mapping rendering" ? 🤣
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/TeaPotMapping_001th.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/KerkyThea/TeaPotMapping_002th.jpg
                                          Extrude Edges by Rails + selection manager + selection memory + Weld + Component Stringer.
                                          I've probably missed the simple way by a4chitect_SmartDrop!! let see.
                                          simon
                                            is that a closeup of SketchUp's voxels? 😄
                                            • 1 / 2
