    Render this: LCD screen (light emitting material)
    59 Posts 30 Posters 17.4k Views 30 Watching
    • soloS Offline
      solo
      Al Hart has a render tip floating around regarding back lighting, I thought we could expand on that slightly and have a challenge to render an IPhone, with an LCD screen.
      Sure there are many other textures, but what this exercise is about is the screen, as you will notice is that it's an image and not a flat color, so there are going to be many ways of achieving this result.
      I'd suggest a dark environment and maybe posing the phone in a way that the light can reflect on a surface, but that's your deal.
      I chose an IPhone as it's universally recognisable, small and has a great bright display.
      Have fun.
      The IPhone is a little heavy, that's because it is well smoothed for better results and the screen image is a decent resolution for render.
      Iphone.skp
      http://www.solos-art.com
      • E Offline
        Ecuadorian
        Public perception of the iPhone at the time of launch:
        -Miguel Lescano
        • soloS Offline
          solo
          My first try.
          I tried to get the screen to emit light as well as reflect the light from adjacent IPhones.
            jopsa2
            I actually tried this a while back, while eagerly waiting for my ipod touch to ship.
            i think the noise is due to the low quality HDRI
            • E Offline
              Ecuadorian
              The only light source here is the iPhone screen:
              -Miguel Lescano
                I use Twilight and was wondering how to get the home screen to emit light and be reflective at the same time?
                Can i set it as glass and 'Fake Emitter' simultaneously?
                Good challenge Pete 👍
                • E Offline
                  Ecuadorian
                  Rich, why not build it just as it would be in real life? Put the glass over the emitter.
                  -Miguel Lescano
                  • EscapeArtistE Offline
                    EscapeArtist
                    First run. Ok except the apple fell off somewhere!
                    (Updated: changed materials a little.)
                      Chris_at_Twilight
                      I used modeling to provide the emitter / reflection combination. I moved the screen back a tiny bit and placed another "plastic" surface in front. Made the apple glow, just because. 😉
                      http://www.TwilightRender.com
                      • stefanqS Offline
                        stefanq
                        V-ray renders, studio setup, I just used the same texture from diffuse, for the emissive layer of the v-ray material.
                        http://img140.imageshack.us/img140/4426/iphone1z.jpg
                        http://img685.imageshack.us/img685/805/iphone2d.jpg
                        • soloS Offline
                          solo
                          2nd try, used light caustics.
                          and a very low res .gif.
                          http://img694.imageshack.us/img694/7915/iphone.gif
                            lexmonteiro
                            This Is "TWiphone"!
                            Twilight 6 minutes:
                            • RichardR Offline
                              Richard
                              very nice!!!
                              BUILTBRAND.COM.AU
                              • EarthMoverE Offline
                                EarthMover
                                Finally had a few minutes to throw these into the mix. Great renders all the way around from everyone!
                                Content Creator at Skapeup
                                • N Offline
                                  notareal
                                  Adam, I like the composition of Iphone_LED2.jpg. Good looking materials, except there is something odd going with the table lamp; ceramic base has some material (or surface normal) problem with the grazing angle.
                                    EarthMover
                                    Thanks Notareal. I adjusted the material and got a better result. Also added an HDRI for fill light.
                                    • FrederikF Offline
                                      Frederik
                                      Excellent render, Adam... 👍
                                      What render app. did you use...??
                                      Cheers
                                      Kim Frederik
                                        EarthMover
                                        Thanks Kim. I used Vray for Max with the Solid Rocks plugin for render settings. Vray light material for the LCD.
                                        • charly2008C Offline
                                          charly2008
                                          A quick Photon render with Kerkythea. Again something learned about emitting light. Thanks Pete
                                          Karlheinz
                                            lexmonteiro
                                            If I may, I would like to try again.
                                            I went to sleep last night thinking of a way to render as quickly as possible without light-emitting materials, and today I woke up and I had the idea to only using projectors, a thin glass to cover the screen, and most importantly, projector must coincides exactly with the image on the screen.
                                            Then I looked at my clock alarm and I think that this may be interesting to show the reflection in the "thin glass" over the Iphone screen, how to do this too...? I put a red light iside the alarm and a red glass on the numbers, the result you see now!
                                            • 1 / 3
