    Sections That Don't Look Hollow
    7 Posts 3 Posters 577 Views 3 Watching
      mpkarch
      Maybe a dumb question but how can I view a section so that the walls, floors, etc. don't look hollow?
      • boofredlayB Offline
        boofredlay
        Welcome mpkarch. There is a plugin called SectionCutFace you can find here:
        http://forums.sketchucation.com/viewtopic.php?f=180&t=1517&st=0&sk=t&sd=a
        It allows you to create a "solid" look with a section cut.
          mpkarch
          Thanks for the link. I will check it out.
            mpkarch
            I copied the file into my Plugins folder but it is not showing up after I close and re-start SketchUP.
              boofredlay
              Make your section then right click (context click) on the section itself, that is where it shows up.
              • E Offline
                Ecuadorian
                Also, check this:
                http://www.forums.sketchucation.com/viewtopic.php?f=18&t=21963
                -Miguel Lescano
                  mpkarch
                  Thanks to both of you. I will check out the other link.
