    Su to KT
    extensions
    11 Posts 4 Posters 1.3k Views 4 Watching
      Rudbeckia
      Hello
      I am importing from Su to Kerkythea, and loosing materials, see attached pic, the stairs and the patio are all the same material, same name, etc, why does the patio only show up in KT, any thoughts?
      • FrederikF Offline
        Frederik
        It's difficult to say... 😐
        I assume that you've applied the texture to the back-side of the surface... 😕
        Check to see this in SU...
        In KT, you can also select the material and see where it's applied...
        Cheers
        Kim Frederik
        • E Offline
          Ecuadorian
          Try exporting everything by material, not as components or instances.
          -Miguel Lescano
          • N Offline
            notareal
            Excessive reflection in stairs indicates that you have applied texture to back-side. If you look stairs there is actually texture, it's just really faint.
              Rudbeckia
              Okay, so I need to take the textures off the back side?
              • N Offline
                notareal
                Sertainly! Before you apply any texture to model, make sure that there are no blue faces (back-face) visible. Textures should be applied only to front face (white).
                  Rudbeckia
                  thanks! I actually applied the same texture to the front and the back of face and that seems to be working, its that incorrect?
                  • N Offline
                    notareal
                    Exporter should handle that situation too. Just make sure that there are no visible back-faces and front face has a texture. Then e back-face with texture will be ignored.
                      Rudbeckia
                      I started over with all the textures, put them all back to default repainted just the front faces and tried again and it still does not work, starting to piss me off
                      i guess i just need to read more about textures and KT b.c i am doing something wrong
                      thanks for the help though
                      • N Offline
                        notareal
                        Please, read the KT getting started tutorial, again with the care.
                        http://www.kerkythea.net/phpBB2/files/front_back_101.jpg
                        Image by Frederik
                        Lets continue this topic at KT forums. No need to split this discussion at two different sites.
                          Rudbeckia
                          Image by Frederik
                          okay thanks! sorry did not know I was talking to the same person on both forums
