    Changing line end points
    7 Posts 3 Posters 694 Views 3 Watching
    • L
      lapx
      Is there a ruby script that will change all selected lines to a given elevation. I tried to use flatten but this doesn't seam to work. Im trying to close a face from thelines. I'm guessing that the endpoints may be at different elevations. It would be nice to select all lines and be able to change all endpoints to desired elevation via VCB.
      • thomthomT
        might be that there's a small gap between them...
        • L
          lapx
          no stray lines. im assuming different elevations.
          • GaieusG
            Come on, Thom, you have a perfect plugin to flatten those lines IF they are indeed closed:
            http://forums.sketchucation.com/viewtopic.php?f=180&t=23491
            πŸ˜‰
            • thomthomT
              πŸ˜‰
              I assumed that was what he tried... πŸ˜•
              • GaieusG
                Well, maybe you're right (and I should be more careful when reading?) πŸ˜’
                • L
                  lapx
                  The flatten I used was a different flatten from Thom's script. I sovled the problem by editing the end points manually. I will have to try "tt-flatten" .
                  Thanks Thom.
