Face styles
I have just started using layout. Until now I have used indesign, but wanted to give layot a change to see if I could be more effective.
I now got my first problem. I add a scene in layout. In SU the faces are "hidden line", this shows fine in layout. But when I change is to some exact scale the facestyle goes to something like "shaded with textures"
Does anyone know if it's possible to change the facestyle inside layout ?
Thanks... really need a solution
Jorgensen -
found a solotion. Had to change the style inside layout to another style and then back again.
JorgensenIs the Scene created in SketchUp, or do you mean you just inserted a SU model in LO?
Did you select an SU Scene inside LO from the SU Dialog? -
hi jhauswirth
I created the scenes inside SU.
@jorgensen said:
hi jhauswirth
Select the model in LayOut and look in the SU dialog's Styles'
tab. Do you see a style called "Modified Active Style" or a
style with (Modified) in front of it?
(probably the one that's selected)
