    Face styles
    layout
    5 Posts 2 Posters 1.2k Views 2 Watching
      Jorgensen
      I have just started using layout. Until now I have used indesign, but wanted to give layot a change to see if I could be more effective.
      I now got my first problem. I add a scene in layout. In SU the faces are "hidden line", this shows fine in layout. But when I change is to some exact scale the facestyle goes to something like "shaded with textures"
      Does anyone know if it's possible to change the facestyle inside layout ?
      Thanks... really need a solution πŸ˜•
      Jorgensen
        Jorgensen
        found a solotion. Had to change the style inside layout to another style and then back again.
          jhauswirth
          Jorgensen
          Is the Scene created in SketchUp, or do you mean you just inserted a SU model in LO?
          Did you select an SU Scene inside LO from the SU Dialog?
            Jorgensen
            hi jhauswirth
            I created the scenes inside SU.
              jhauswirth
              @jorgensen said:
              hi jhauswirth
              Select the model in LayOut and look in the SU dialog's Styles'
              tab. Do you see a style called "Modified Active Style" or a
              style with (Modified) in front of it?
              (probably the one that's selected)
