    Twilight v1.1
    extensions
    25 Posts 12 Posters 3.6k Views 12 Watching
      Chris_at_Twilight
      Just want to put a little blurb out about the latest Twilight release!
      Announcing our next release, version 1.1!!
      The big new features we've added:
      Several languages available:
      • Spanish
        • French
        • Chinese (simplified and traditional)
        • Japanese
        • German
      You can choose your language from Options -> Twilight Languages.
      A huge thanks to all those who helped put those translations together!!!
      A new View-and-Framing Tool:
      *  Frames exactly what will be rendered and adds guide lines to aid composition
      *  Condenses pan, orbit and look around functions into one handy tool
      *  Allows you to accurately set the focus distance without reorienting the camera
      This replaces two previous features: The "letterboxing" seen when you uncheck the 'Fixed Aspect Ratio' checkbox, and the "Set Camera Target" context menu choice. You are no longer limited to 'focusing' only on objects in the center of the view. Orbit around the 'highlighted' geometry point instead of some mystery point. All action is done with the left mouse button, leaving the middle mouse button available for the traditional SketchUp orbit tool.
      And a lot more fixes and features
      New Licensing Mechanism (Don't worry, your existing license is still fine!!)
      Projector Lights image improvements
      Material editor improvements
      SSS material template has been redone to give dramatically better results.
      Layers in components are rendered as they are visible, by default. You can choose to render "All Layers" from the context menu.
      Transparency of TGA images is now directly recognized.
      Save rendered images as EXR
      And More!
      http://www.TwilightRender.com
      • soloS Offline
        solo
        Sounds excellent.
        What I like is my SSS thread got y'all to optimise your engine to facilitate, always great to know the developers are watching, learning and improving their products.
        http://www.solos-art.com
          Works fine ☀
          Fontain by Solo
          • X Offline
            xrok1
            “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
            • E Offline
              Ecuadorian
              It would be better to do the celebrations and discussion of new stuff in the proper place instead of here 😉 :
              http://www.twilightrender.com/phpBB3/viewtopic.php?f=18&t=969
              -Miguel Lescano
              • X Offline
                xrok1
                don't be that way! we need something to discus and this totally relates to SU. 😉
                • EscapeArtistE Offline
                  EscapeArtist
                  This is a bit OT, but I downloaded the demo and gave SU/Twilight a shot. Slick & easy interface. One question that's bugging me; I noticed several folks used twilight to render in the "Render This :SSS" thread, and came up with smooth surfaces. I rendered a cube & sphere similar to the ones in the thread and wound up with a very faceted sphere, even with SD&S applied to it. I'm used to Kerkythea where I just select the material and tell it "smooth", what's the secret in TW?
                  • E Offline
                    Ecuadorian
                    That happens from time to time; it's simply weird. Usually solved by just grouping the geometry or ticking "weld vertices" in the material editor. Of course, you'll get better replies from the tech support guys (Fletch, Chris and Frederik) if you post in the TWL forum.
                    -Miguel Lescano
                    • X Offline
                      xrok1
                      i think there are more twilight users here than there. 😄 take YOU for example. No.1 tech support guru.
                      • halroachH Offline
                        halroach
                        Sounds Good!
                        I just recently started twilighting around... keep them updates coming! 😄 fun fun!
                        FlexTools - Super Quick Windows, Doors, Slats...
                          chango70
                          How do I update then?
                          • FrederikF Offline
                            Frederik
                            Simply install it on top of previous versions... 😉
                            Cheers
                            Kim Frederik
                              chango70
                              Download the demo version?
                              • halroachH Offline
                                halroach
                                Yes, download the demo. it worked for me.
                                I was confused with that too... I think the website should be clearer about how updates are obtained and installed
                                • FrederikF Offline
                                  Frederik
                                  Fair point... 👍
                                  I will make sure that we do it better in the future... 😉
                                  Although Chris posted this announcement here at the SCF, I recommend that users always search about things on the TWR Forum...
                                  Posts here at the SCF should be seen as a service, similar to how other applications are posting such announcements...
                                  Please see the Version 1.1 thread... 😄
                                  Cheers
                                  Kim Frederik
                                    chango70
                                    Downloaded v1.1 demo, installed it, my license is gone. It says i have a demo version now. What the hell?
                                      remus
                                      Are you still running the very first version by any chance? i remember having a similar problem after my first upgrade (to a maintenance release.)
                                      You can easily get another license through the usual method by the way, its just a bit of a faff.
                                      • FrederikF Offline
                                        Frederik
                                        I can only assume that you didn't have the latest version (ver. 1.0.19)
                                        installed... 😐
                                        Any way... Unless you're installing TWR on another computer or have upgraded the OS, you can simply use and install the license key you've received previously... 😉
                                        (If you haven't got this anymore, you need to request a new license key...)
                                        Cheers
                                        Kim Frederik
                                        • E Offline
                                          Ecuadorian
                                          Chango, I can easily see the reason in your OS info: You're running Vista 64-bit and according to the new version announcement, those running Vista 64-bit and Windows 7 64-bit might have to re-request their licenses only if they never upgraded to TWL 1.0.19 (which introduced a change in licensing for 64-bit OSs), which seems to be your case.
                                          BTW, has anyone noticed this is already the fourth TWL release? You should check the forum more often, TWL moves really fast. 👍
                                          -Miguel Lescano
                                          • david_hD Offline
                                            david_h
                                            I downloaded and installed but when I went to the TW Options/About menu it still reads version 1.0. Am I doing something wrong here?
                                            • 1 / 2
