    Animation for Mosque
    8 Posts 6 Posters 843 Views 6 Watching
    • S
      sheir
      Would like to share my last design & animation by sketchup
      This is my first animation with Sketchup
      any comments are welcome in the design & animation
      • A
        Aerilius
        Very interesting! It reminds me of the huge Mosque in Cologne which was begun this month.
        Really good work for that it's your first animation. I haven't finished my first one yet and I was much inspired of how you set up the music and text animation.
        Maybe you could try it with a higher frame rate (and the car is flying a bit over the ground).
        • S
          sheir
          Aerilius,
          Thanks,
          You can make text ,sound and more by free program
          Windows Movie Maker 2.6, you can download it from internet.
          It's so easy to use.
          • M
            MtnArch
            Sheir -
            I really like contrast of the arches in CMU/brick with the cement plaster in the corners against the glass. Very nice articulation - almost like a negative photograph!
            Highest Regards,
            Alan T. Hendry, RA
            Architect
              Remember this movie πŸ˜‰
              • GaieusG
                Hi Sheir and welcome to the forums (glad you made it to the registration - you "help" email is delivered to me but then I saw you already registered).
                BTW my FIRST model I made was also a mosque (true that a 16th century, Ottoman-Turkish "cami" from the time they occupied my city/country).
                Yours is really intriguing work! πŸ‘
                • S
                  sheir
                  Aerilius,
                  Thank for you reply
                  • Jean LemireJ
                    Jean Lemire
                    Hi Sheir, hi folks.
                    Very good result for a first animation.
                    The only problem I see, unless my eyes play a trick on me, is that the model seems to float a few centimeters over the ground plane where all the shadows can be seen. For example, there is a gap between the car tires and the ground as well as between the base of the columns and the ground.
                    Try moving the whole model on the ground plane.
                    And, by the way, welcome to SCF and keep up the good work.
