    Mass rename components
    23 Posts 6 Posters 11.4k Views 6 Watching
      dedmin
      Is there a way to attach a same string to the names of different components?
        Sketchup.active_model.definitions.each{|d|
          d.name="MyPrefix-"+d.name+"-MySuffix"
        Adds a prefix AND a suffix to ALL component definition names !
        If you want to match a particular kind of name then use a regexp...
        ...d.name=d.name+"-MyDoorSuffix" if d.name=~/Door/...
        would only add '-MyDoorSuffix' onto the ends of any Component names that include the text 'Door' somewhere inside it...
          dedmin
          Thanks, Master TIG πŸ‘
          How about applying this on a selection of components?
          What I'm trying is to add a banding information to the names of the components as a suffix. If I have a components that share the same banding, to first select them and attach that suffix at once.
            defs=[]
            Sketchup.active_model.selection.each{|e|
              defs<<e.definition if e.class==Sketchup;;ComponentInstance
            defs.uniq!
            defs.each{|d|d.name=d.name+"-SUFFIX"}
            This processes the definitions - I'm assuming that you want to rename the component-definition NOT the component-instance which can also have a separate name... It's easy to adjust the code if instances are to be renamed... like this...
            insts=[]
              insts<<e if e.class==Sketchup;;ComponentInstance
            insts.each{|i|i.name=i.name+"-SUFFIX"}
            ### NOTE; the component-definition's name is NOT changed by this...
              dedmin
              Thanks!! Yes, I want to change component-definition.
              I saved the ruby as a banding.rb in the Plugins folder, selected the components and run the script in the ruby console. Never been messed with this before - maybe I'm doing something wrong here?
              banding
              Error; #<NameError; (eval);42; undefined local variable or method `banding' for main;Object>
              (eval);42
                Without seeing your code I don't know what's up - what have you pasted into the file - I only showed snippets which need some 'structure' ! You have to have
                def banding()
                 ### The code...
                end#def
                To run it by typing 'banding'...
                It'd be relatively easy to sort - please paste you code inside a [ code ][ /code ] set...
                  dedmin
                  I see. I thought it's a finished script ready to run. Never touched any scripting before. Thanks - will do it by hand.
                    Copy/paste this into a banding.rb file, then typing banding "-suffix" in the console should work on selected components...
                    def banding(suffix="")
                      suffix=suffix.to_s
                      model=Sketchup.active_model
                      model.start_operation("banding "+suffix)
                      ss=model.selection
                      defs=[]
                      ss.each{|e|
                          defs<<e.definition if not defs.include?(e.definition)
                        end#if
                      defnames=[]
                      defs.each{|d|
                        d.name=d.name+suffix
                        defnames<<d.name
                      puts "Processed "+defs.length.to_s+" Component Definitions"
                      defnames.each{|n|puts n}
                      puts ""
                      model.commit_operation
                    end#def
                    PS: I've attached the .rb too...banding.rb
                      dedmin
                      banding "-0W-1L"
                      Processed 2 Component Definitions
                      drawer_right-0W-1L
                      drawer_left-0W-1L
                      true
                      It works!!!!
                        dedmin
                        It works great, but there is a problem. If I make a cabinet component with all the banding info for the parts set and then stretch with FredoScale to get new dimensions the components get renamed
                        drawer_left;0W-1L#1
                        • they become new components. Since i'm using the names as a way to export banding info into the CutList Plus using ";" as a delimiter i have to rename again. But if i put this info as a prefix then everything will be fine and no need to rename again. Can You please make this script do the same but as a prefix? Sorry, if i sound too insolent 😳
                          dedmin
                          true
                          banding "0W-1L;"
                          0W-1L;drawer_right
                          0W-1L;drawer_left
                          true
                                     :+1:  :+1:  :+1:  :+1:
                            Here's an update:banding.rb
                            Usage:
                            banding "prefix-" [or banding "prefix-","" or banding "prefix-",nil] adds a prefix
                            banding "","-suffix" [or banding nil,"-suffix"] adds a suffix
                            banding "prefix-","-suffix" adds a suffix and a prefix
                              DavorP
                              Is there a plugin that would export list of component names, definitions and perhaps other details to .csv file
                              And the more tricky part - to import back the new filenames after you are done with editing?
                              Or a plugin that would list all components with details in an editable spreadsheet within SU?
                              • Dan RathbunD Offline
                                Dan Rathbun
                                What "other details" ?
                                I'm not here much anymore.
                                  jeynay
                                  Is there a way to remove certain words from multiple components at the same time?
                                  for example I have 50 components that their name has "3D - johnsmith_google_com level 1" at the end of the name. like:
                                  "10016001_S_DLGBldg1_Central_detached_rvt-1-3D - 3D - johnsmith_google_com level 1"
                                  "4_ Light Fixture - 4_ Light Fixture-1847101- 3D - johnsmith_google_com level 1"
                                  "Aluminum Sill Extension - Aluminum Sill Extension-2131210-3D - johnsmith_google_com level 1"
                                  Is there a script that can remove a certain prefix or suffix? or just removing the first/last 15 or 10 characters in the name would also work.
                                  This issue is very annoying since the models imported from revit to sektchup end up having more than 100 characters. πŸ˜•
                                    @jeynay said:
                                    You can batch rename components.
                                    I assume you mean component-definitions, rather than component-instances which can have individual names based on a shared definition...
                                    Here's a simple one-liner to do it...
                                    Edit the initial togo="..."; to suit your needs...
                                    togo=" - 3D - johnsmith_google_com level 1";m=Sketchup.active_model;m.start_operation('rename defns',true);c=0;m.definitions.each{|d|(d.name=d.name.gsub(/#{togo}/,'');c+=1) if d.name=~/#{togo}/};puts"#{c} definitions renamed.";m.commit_operation;
                                    Paste it into the Ruby Console + <enter>, it's one step undoable...
                                      jeynay
                                      Thanks for the quick reply TIG.I'm assuming this would rename that portion of component's name as well? for exampe if i have 50 instances like
                                      "4_ Light Fixture - 4_ Light Fixture-1847101- 3D - johnsmith_google_com level 1-01"
                                      "4_ Light Fixture - 4_ Light Fixture-1847101- 3D - johnsmith_google_com level 1-02" so on so forth, would i be able to remove the" 3D - johnsmith_google_com level" portion of those instance names?
                                      Thanks in advance
                                      @tig said:
                                      @jeynay said:
                                        The initial part of the code snippet togo=" - 3D - johnsmith_google_com level 1";
                                        specifies which string will be deleted in the components' names.
                                        I you example:
                                        "4_ Light Fixture - 4_ Light Fixture-1847101- 3D - johnsmith_google_com level 1-01" "4_ Light Fixture - 4_ Light Fixture-1847101- 3D - johnsmith_google_com level 1-02"
                                        etc
                                        become
                                        "4_ Light Fixture - 4_ Light Fixture-1847101-01" "4_ Light Fixture - 4_ Light Fixture-1847101-02"
                                        etc
                                        Just edit that to cover what you want to delete...
                                        So to leave the final 'ref' as say "1-01", you simply change the togo to say:
                                        togo=" - 3D - johnsmith_google_com level";
                                        and the renaming is then:
                                        "4_ Light Fixture - 4_ Light Fixture-1847101 1-01" "4_ Light Fixture - 4_ Light Fixture-1847101 1-02"
                                        etc
                                        You choose what's to be deleted...
                                        You can always run the code a second time with a new togo string, e.g.
                                        togo="4_ Light Fixture - ";
                                        Would strip off the duplicated starting reference, leaving:
                                        "4_ Light Fixture-1847101 1-01" "4_ Light Fixture-1847101 1-02"
                                        etc
                                          jeynay
                                          I you example:
                                          etc
                                          become
                                          etc
                                          etc
                                          etc
                                          This worked beautifully!!! thank you much appreciated πŸ˜„
                                            MAdel
                                            thanks TIG for those amazing scripts
                                            i hope you could add the option for
                                            removing the first/last 15 or 10 characters from the name
                                            @tig said:
                                            @jeynay said:
                                            • 1 / 2
