    Problem with Rhombus and Rotate Tool
    4 Posts 3 Posters 380 Views 3 Watching
      Tinux
      Hi Everybody, i can't do something which i think was simple in my brain...
      This is what i would like to have (each Rhombus are the same : 3000x3000x3000x3000 at 120Β°) :
      http://img204.imageshack.us/img204/9746/losanges.th.jpg
      But this what i have always :
      http://img214.imageshack.us/img214/331/losanges2.th.jpg
      So how you do that ?
      Thanx a lot in advance !!!!
      Tinux.
      • jeff hammondJ Offline
        jeff hammond
        some of the angles are variable (i used 30deg in this case)
        using the shift key to get the rotate tool locked to certain axes helps a lot here.. let me know if you need a better explanation.
        a possibly un-understandable step-by-step πŸ™‚
        dotdotdot
          Tinux
          Ahhhh !
          I understand ! Before i think i started with the wrong pair... Your explication in your file was very clear ! I can now fix the angle with the degre i want first and then fit the other rhombus !
          Thanx a lot, you save my time lost trying different manners to got that!
          • Jean LemireJ Offline
            Jean Lemire
            Hi folks.
            See this SU file for ideas.
            Quicker mirror copy.skp
