    Render this: SSS
    174 Posts 44 Posters 33.3k Views 44 Watching
      dacad
      Ecuadorian
      If i'm not mistaken the BPT is better suited for interiors, other way there's no much diference between btp and MLT. You should try the two in a interior room with lighs coming from the windows with real glass just with sun to see the big diferences.
        tallbridgeguy
        Is this kinda sss?
        thanks!
        Nielsen
        http://www.tallbridgeguy.com/
        • EarthMoverE Offline
          EarthMover
          Torus Knot emitter, inside of ice, inside of honey. FryRender - 15% Isotropic Scattering with 85% Dielectric Transmittance.
          Content Creator at Skapeup
            EarthMover
            TBG - It is to a degree, although it appears to be more of a frosted glass. With SSS you'd expect to see less light absorbed into the thicker areas (i.e. the corners of the cube) and more light absorbed into the thinner areas (those closest to the sphere). In your render you can see the light passing through the thick areas too uniformly to be a true rendition of what SSS would look like. The dark areas in your render appear to be more shadow casting than that of light block through physical density. Keep trying though...you're getting closer.
              tallbridgeguy
              Thanks for the help! It is an interesting subject and I appreciate the feedback. I have to say it is a difficult subject.
              s
              Nielsen
              • olisheaO Offline
                olishea
                frosted glass and a shiny ball! my god sss takes long time to render! this ones not exactly sss but looks pretty cool!
                earthmover: those look sweet! could be ornamental lights!
                oli
                • david_hD Offline
                  david_h
                  here's one. . .no idea what I am doing. Just clicking a lot of buttons and hoping for the best. 😲
                  • jeff hammondJ Offline
                    jeff hammond
                    whaat's wax.. no ambient
                    http://homepage.mac.com/jeffhammond/.Public/scf/ssswax.jpg
                    dotdotdot
                    • olisheaO Offline
                      olishea
                      we should be using an organic model for SSS:
                      this is with some fake emitters within rubber ball material, SSS density 0.05
                      oli
                      • soloS Offline
                        solo
                        Fair enough, maybe my model is a little challenging as it requires very specific materials in order for overlapping textures to display SSS.
                        So here is a Dragon as previously requested, feel free to do the SSS light effect. I used this model as if you do an Internet search on subsurface scattering you will find this particular one most used (think of it as the Barcelona chair of SSS)
                        Dragon 1.zip
                        http://www.solos-art.com
                        • 7 Offline
                          7homuz
                          my try, this is fun! had a couple tries but was very baddddddddddd
                          hopefully this one is ok, rendered it when i was sleeping
                          • soloS Offline
                            solo
                            I did a quick one using the studio setup from the other thread and three lights.
                            • daleD Offline
                              dale
                              Before I put myself into the mouth of the dragon I will post these
                              • 7 Offline
                                7homuz
                                now you just need a jade sss material
                                • daleD Offline
                                  dale
                                  and one more
                                  • olisheaO Offline
                                    olishea
                                    nice pete, looks real! good thread mate, dont get to use sss at all really.
                                    oli
                                    • dermotcollD Offline
                                      dermotcoll
                                      This is my last attempt at this - The SSS material in the twilght library didnt render well at all as the cube material turned out very flat. This one came out very interesting with the HDRi image really affecting it. I'm learning alot using this tutorial
                                      When you burn your arse - you gotta sit on the blisters!!
                                      • E Offline
                                        Ecuadorian
                                        After doing some more research on the subject now I think some of the renders here show more absorption than SSS. The classic example of an SSS material is human skin.
                                        Thanks for the dragon, Pete, I'll give it a go tonight.
                                        -Miguel Lescano
                                          remus
                                          Cheers for the standford dragon model solo, ive tried getting it in to SU a few times but its always been to heavy. I guess you poly reduced it a lot before taking it in to SU?
                                          • soloS Offline
                                            solo
                                            Pleasure guys, yeah Remus I reduced it 90%, so lots of fine detail is lost.
                                            Miguel, SSS has many factors, human skin is an example of the Translucency of a material as well as forward absorbsion. Jade will have less translucency, more refraction and slight absorbtion.
                                            Here is my attempt at Ruby material, as well as my settings.
                                            • 8
                                            • 9
                                            • 3 / 9
