    Render this: SSS
    174 Posts 44 Posters 47.5k Views 44 Watching
    • T
      tallbridgeguy
      I looked on the kerkythea forum and found some more info on SSS. (actually today was the first time I ever heard of sss.)
      s
      Nielsen
      http://www.tallbridgeguy.com/
        dacad
        Ecuadorian
        If i'm not mistaken the BPT is better suited for interiors, other way there's no much diference between btp and MLT. You should try the two in a interior room with lighs coming from the windows with real glass just with sun to see the big diferences.
        • T
          tallbridgeguy
          Is this kinda sss?
          thanks!
          Nielsen
          • EarthMoverE
            EarthMover
            Torus Knot emitter, inside of ice, inside of honey. FryRender - 15% Isotropic Scattering with 85% Dielectric Transmittance.
            Content Creator at Skapeup
            • EarthMoverE
              EarthMover
              TBG - It is to a degree, although it appears to be more of a frosted glass. With SSS you'd expect to see less light absorbed into the thicker areas (i.e. the corners of the cube) and more light absorbed into the thinner areas (those closest to the sphere). In your render you can see the light passing through the thick areas too uniformly to be a true rendition of what SSS would look like. The dark areas in your render appear to be more shadow casting than that of light block through physical density. Keep trying though...you're getting closer.
              • T
                tallbridgeguy
                Thanks for the help! It is an interesting subject and I appreciate the feedback. I have to say it is a difficult subject.
                s
                Nielsen
                • olisheaO
                  olishea
                  frosted glass and a shiny ball! my god sss takes long time to render! this ones not exactly sss but looks pretty cool!
                  earthmover: those look sweet! could be ornamental lights!
                  oli
                  • david_hD
                    david_h
                    here's one. . .no idea what I am doing. Just clicking a lot of buttons and hoping for the best. 😲
                    • jeff hammondJ
                      whaat's wax.. no ambient
                      http://homepage.mac.com/jeffhammond/.Public/scf/ssswax.jpg
                      • olisheaO
                        olishea
                        we should be using an organic model for SSS:
                        this is with some fake emitters within rubber ball material, SSS density 0.05
                        oli
                        • soloS
                          Fair enough, maybe my model is a little challenging as it requires very specific materials in order for overlapping textures to display SSS.
                          So here is a Dragon as previously requested, feel free to do the SSS light effect. I used this model as if you do an Internet search on subsurface scattering you will find this particular one most used (think of it as the Barcelona chair of SSS)
                          Dragon 1.zip
                            7homuz
                            my try, this is fun! had a couple tries but was very baddddddddddd
                            hopefully this one is ok, rendered it when i was sleeping
                            • soloS
                              I did a quick one using the studio setup from the other thread and three lights.
                              • daleD
                                dale
                                Before I put myself into the mouth of the dragon I will post these
                                  7homuz
                                  now you just need a jade sss material
                                  • daleD
                                    dale
                                    and one more
                                    • olisheaO
                                      olishea
                                      nice pete, looks real! good thread mate, dont get to use sss at all really.
                                      oli
                                      • dermotcollD
                                        dermotcoll
                                        This is my last attempt at this - The SSS material in the twilght library didnt render well at all as the cube material turned out very flat. This one came out very interesting with the HDRi image really affecting it. I'm learning alot using this tutorial
                                        When you burn your arse - you gotta sit on the blisters!!
                                        • E
                                          Ecuadorian
                                          After doing some more research on the subject now I think some of the renders here show more absorption than SSS. The classic example of an SSS material is human skin.
                                          Thanks for the dragon, Pete, I'll give it a go tonight.
                                          -Miguel Lescano
                                            remus
                                            Cheers for the standford dragon model solo, ive tried getting it in to SU a few times but its always been to heavy. I guess you poly reduced it a lot before taking it in to SU?
                                            • 3 / 9
