    Accurately drawing on a cylinder?
    4 Posts 3 Posters 667 Views 3 Watching
    • A
      Align
      the other day i was drawing a building when i a thought occurred to me to draw windows all around the cylinder. you cant just draw normally, because you have to make it look realistic. if you try drawing like you would on a surface, the windows are uneven in there dimensions and shape. so what do you do?
      • GaieusG
        You would probably intersect your window shape with the cylinder. Depending if you want curved window frames and sills,maybe even several times. Like in the model in this post (not a whole cylinder - just a half - but the idea is the same).
        • H
          Howard leslie
          A couple of possible methods you might try:
          1. Draw a shape through the cylinder (a shape that's grouped) and then do an intersect (as Gaieus has already suggested)
          2. Try out Fredo's ToolsOnSurface Plugin
          Hope this helps
          Howard L'
          • A
            Align
            i am aware that tools on surface will do this, but i don't know how to do it with tools on surface? reading the manual now.
